XT scare
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: XT scare
    Posted: 01 Jun 2022 at 10:09pm
My son went to retrieve a spare wagon on my XT. He brought the wagon which we switched out with the full one. I proceeded to pull it down the road to our farm. She was low on power, virtually no smoke. I thought the turbo had went out or was having a pump issue. Everything on the engine looked fine. Got back to the farm really low on power. Thinking the worst I shut her down. As it turned out I noticed as I shut the fuel off I didn’t push it as far as normal. And then it hit me, he didn’t pull the fuel knob out all the way! Can’t be that simple right? Fired her up and she was back to normal. Man what a relief, scared the crap out of me. My son now knows always give it a full pull.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 4:38am
Wow that turned for the better! I know what you mean how you felt!
Blue Skies and Tail Winds
                          Dana
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 7:09am
Glad it worked out for you.
I guess we all hold our breath every time one of these old tractors doesn't sound or act right!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 8:02am
Had that happen on a 4440 deere last fall working for the neighbor. It is kind of a head scratch-er!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 9:10am
The fuel shutoff on the Roosa pump does simply close down the metering valve part way when not all the way to run. It can simply cut down the fuel delivery. It is exactly what the adjustment of the torque screw does. we adjust the fuel delivery down to our desired setting when on the stand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 9:50am
Back in the day (1977-78) we had an issue with the fuel shut off knob working itself inward while operating the tractor. There was a service bulletin to disconnect the shut off cable wire end, pull the knob out six inches and put a kink in the wire and reinstall. They had changed vendors on the shut-off cable and it had too little friction to keep itself pulled out, so we had to create drag on the wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 10:19pm
Wanted to post this so others could see what happens when full fuel isn’t applied to the pump. It has never happened before because myself or my brothers run my XT. My son has ran it also but not as much. When I told him what happened he said dad, this is your baby, I guess I didn’t want to pull too hard so I wouldn’t damage anything. Lol, he knows how much I love my XT!! The fuel shut off works as it should, I guess I am proud my son for wanting to make sure he didn’t damage anything. Sure scared the crap out of me though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2022 at 10:22pm
Thanks Doc and Ed for chiming in with good explanation. I’m just glad all is well.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2022 at 5:56am
With fuel prices they way they are, you have to save where you can Smile
1968 D15D,1962 D19D
