WTF....What The Fuel .... |
Page <12 |
Les Kerf
Posted: 16 Jun 2024 at 2:33pm |
Disconnect the air filter
rasman57
Posted: 16 Jun 2024 at 3:22pm |
Did that early on as well as restricting it a bit to determine vacuum. Plenty of vacuum. Open Carb without air filter does nothing as well.
Joined: 11 Sep 2009 Location: illinois Points: 88450 |
Posted: 16 Jun 2024 at 3:51pm |
you say it happens when you HIT the throttle real fast... Im wondering if the governor is not set quite right and having touble keeping up...Then it might take a few seconds to get back into proper ........ not sure why it would happen only when HOT ... but something to consider..
Straanger
Posted: 16 Jun 2024 at 3:55pm |
I would try running a new ethanol safe fuel line directly from the fuel tank to the carb inlet, eliminating all of the old fuel lines and give that a shot.
Les Kerf
Posted: 16 Jun 2024 at 8:42pm |
That can happen with a bad coil wire, bad spark plugs or cables, and also with a distributor cap or rotor that has carbon tracking inside. Try running in total darkness and watch for fireworks.
Edited by Les Kerf - 16 Jun 2024 at 8:43pm |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 8860 |
Posted: 17 Jun 2024 at 9:20pm |
If a guy wanted to try a new coil and condenser for D15 Series II with 160 engine, is that a part number available from NAPA or some other auto parts store? D15 I'm in charge of is doing something similar.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5248 |
Posted: 17 Jun 2024 at 9:26pm |
We have tried our local Carquest, took 3 sets of condensers to get a good one. Went back to AGCO because I got tired of the crap I was getting locally. Our local NAPA hasn’t been any better as a matter of fact they don’t carry much for tractors anymore. I don’t even check with them anymore. Maybe your NAPA store will be better. Rebuilt our series II D15 2 years ago.
Edited by AC720Man - 17 Jun 2024 at 9:27pm |
Page <12 |
