WTF....What The Fuel ....
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 2:33pm
Originally posted by rasman57 rasman57 wrote:
... The shutting down and firing right back up is instructive to me for air infiltration that seems to reset once the engine stops...
Disconnect the air filter
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 3:22pm
Did that early on as well as restricting it a bit to determine vacuum. Plenty of vacuum. Open Carb without air filter does nothing as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 3:51pm
you say it happens when you HIT the throttle real fast... Im wondering if the governor is not set quite right and having touble keeping up...Then it might take a few seconds to get back into proper ........ not sure why it would happen only when HOT ... but something to consider..
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 3:55pm
I would try running a new ethanol safe fuel line directly from the fuel tank to the carb inlet, eliminating all of the old fuel lines and give that a shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 8:42pm
That can happen with a bad coil wire, bad spark plugs or cables, and also with a distributor cap or rotor that has carbon tracking inside. Try running in total darkness and watch for fireworks.
Edited by Les Kerf - 16 Jun 2024 at 8:43pm
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 9:20pm
Check the coil, It can do the same thing as you describe...Wink
If a guy wanted to try a new coil and condenser for D15 Series II with 160 engine, is that a part number available from NAPA or some other auto parts store?
D15 I'm in charge of is doing something similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 9:26pm
We have tried our local Carquest, took 3 sets of condensers to get a good one. Went back to AGCO because I got tired of the crap I was getting locally. Our local NAPA hasn’t been any better as a matter of fact they don’t carry much for tractors anymore. I don’t even check with them anymore. Maybe your NAPA store will be better. Rebuilt our series II D15 2 years ago.
Edited by AC720Man - 17 Jun 2024 at 9:27pm
