WTB : D14 ring gear carrier |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: WTB : D14 ring gear carrierPosted: 05 May 2023 at 5:50pm |
One of my brothers is restoring a D14. He needs a carrier. His is bad. Thanks, Tracy
Mikez
Posted: 06 May 2023 at 12:53am |
What’s the part number Tracy
Posted: 06 May 2023 at 5:54am |
Differential "carrier" ??
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 06 May 2023 at 9:11am |
Did a lot of plowing with one spinning a lot? GET YER FOOT ON THE BRAKE BOY!!!
Joined: 11 Sep 2009 Location: illinois Points: 90822 |
Posted: 06 May 2023 at 9:37am |
would that happen to be the same part as the D15 ??
Posted: 06 May 2023 at 9:40am |
E-Bay..........
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 06 May 2023 at 4:07pm |
There were 2 different Carriers. One with early D-14's that were 6 Volt. Different Carriers for later D-14 that were 12 Volt. G |
Tracy Martin TN
Posted: 06 May 2023 at 8:17pm |
Yes, differential carrier. Tracy
SteveM C/IL
Posted: 06 May 2023 at 8:56pm |
What would that have to do with it? I can see different starter ring gears 6 VS 12.
Posted: 06 May 2023 at 9:49pm |
the piece that the RING GEAR is bolted to is called a "HOUSING" in the parts book and it never did change.... the term "CARRIER" is used by Allis to describe the "bearing holder" on each end of the shaft.... and there was a change after the SN 19xxxxxx .
If your looking for the "ring gear holder" it was always the same.. Many call it the "carrier"... except Allis ! Edited by steve(ill) - 06 May 2023 at 9:57pm |
Tracy Martin TN
Posted: 06 May 2023 at 10:38pm |
Steve, learn something new everyday.I need the housing. Thanks, Tracy
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3814 |
Posted: 07 May 2023 at 12:05am |
I’m parting out a D14 that should have a good differential in it.
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
