WTB Allis Chalmers 5050 rear rim and grille
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: WTB Allis Chalmers 5050 rear rim and grille
    Posted: 01 Dec 2017 at 6:53am
Looking for a good rear rim for an Allis Chalmers 5050 with FWA. The rim size is 13" x 30". The closer to the Grand Rapids Michigan area the better.
As far as I know only the 4 wheel drives had the 30" rear rims, the 2 wheel drives had 28" rims. It needs to be the Fiat style wheels as shown in the picture. I've seen new 14" wide rims, but mine are 13" with a 14.9" width tire.
Also looking for a Grille with screen.
D15D, D17G, 170G, 175D, and two 5050FWA
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 7:58am
The Oliver 1365 used a 30" rim its Fiat built same style rim, I'd have to check the width.
Really I can't see one inch making much difference on those rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 9:40am
I measured a rim the 1365 rim is 13" wide so it'd be an exact fit for your 5050
30" rim.Some Fiat built Longs also had 30" rims they'd probably be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 2:00pm
Thank you, that's good to know. Did you have a 1365 rim for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:09am
I only have one spare good rim and am running 2 1365 tractors so I guess I better
keep the spare.I do have a grille though for the 5050 came off a 5040.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 10:13am
I bought a new PA rim from a guy north of GRR.  He had quite a few rims in his barn.  If he didn't have it, he might be able to make it.  Look on CL for Tractor Tires in the Grand Rapids section.  I'm not sure I have his contact info, but I'll look.
You might be able to get a new blank rim and weld those mounting brackets to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 10:46am
Thanks for the tip. I think I have seen his listing of rims before, but don't remember seeing the size I needed, but it may be worth while giving him a call.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:48pm
Still looking for a rim and grill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2017 at 9:21am
Grill available in above post (Gary). ????
My cousin just bought a 5050, two wheel drive with loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 6:11am
Sent Gary a PM.
