WTB 2300 disk gang bolt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: WTB 2300 disk gang bolt
    Posted: 18 Oct 2023 at 10:52pm
Hello
I’m looking for a gang bolt for 2313. 13’ wide disk. The parts book says the gang bolt is 74-1/2” long. Original part number 586971.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 5:48am
Send the specs to Shoup and have them make you one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:14pm
Thanks Paul but they won’t do hexagon shaft.
Wondering if you switched to square and square bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 10:04pm
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2023 at 8:37am
Btt
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2023 at 9:36am
Weld what you have.  V it out to just little point, then start with 7018.  Give it plenty of time, spend more time cleaning slag than welding. Chip and then wire wheel, make it shin. Then another pass. Lay it in a piece of angle iron, keep turning it at each weld pass to keep it straight. It is hours not minutes spent to get it right.
I have welded the round axles in a medium heavy duty offset drag disc. I have never broke one of my welds, and I am not one of the worlds best welders. I welded them to have a nut on both ends to make replacing broken blades faster. I farm over many rocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2023 at 11:13pm
Ours is bent not broken
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 6:47am
Could it be straightened? 20 ton shop press might do it. Or weld something to it so it won't roll, then wail on it with a sledgehammer. Another option would be to cut a v notch into the high side, then pound it straight. Then weld the notch full. Depending on the bend, might have to notch it in a couple spots.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2023 at 11:24pm
I second straighten it.
I had a bent shaft on a 2600 disk and straightened it on my press. It works good.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
This page was generated in 0.136 seconds.
