WTB 190 belt pulley |
brouillettefarms
Joined: 30 Jan 2013 Location: Vincennes Points: 337 |
Topic: WTB 190 belt pulleyPosted: 09 Dec 2022 at 8:35am |
Looking to buy a flat belt pulley for a 190 any help would be appreciated.
Thanks, Ben 812-881-7654 |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 09 Dec 2022 at 11:13am |
The pulley itself is the same as other D series tractors but the drive assembly is not.
Good luck finding one, they are near impossible to find. You would also need the engaging mechanism that goes in the torque tube. Not all tractors have it. |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 09 Dec 2022 at 1:50pm |
Would one for a 180-185 work as well?
brouillettefarms
Posted: 09 Dec 2022 at 1:56pm |
I believe so, it should have the 11" body
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 11 Dec 2022 at 9:05am |
180-185 has the same torque tube as a OneNinety. Need the internal parts to be functional. Have a belt pulley on my OneNinety.
Adam Stratton
Posted: 11 Dec 2022 at 8:44pm |
Won't a d-series pulley bolt up and function? I don't know if there is some difference in what is correct or not depending if you are going for show or function but I sure think I remember borrowing the assembly from a d14 to put on a 190 gas once and if I'm not mistaken it worked just fine
Calvin Schmidt
Posted: 12 Dec 2022 at 6:55am |
The pulley casting on the D series is 4" shorter. It will work on a OneNinety if the tractor has the internal gear etc. The belt may rub along the side rails.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34641 |
Posted: 13 Dec 2022 at 12:05am |
From the Dealers Parts books of the D19 and the 1964 190; the shaft and the housing and mount bolts were the only parts different. bearings, seal, shims, gear, shaft nut and pully were the same.
D19 - shaft - part number 230235 housing- 228595 capscrews 920583 190 - shaft- 243033 housing- 243032 capscrews 923494 Allis provided a drive for the air conditioner pump for their cabbed tractors from the belt pully drive at one time. and
there was an adapter to put in the belt pully hole to drive hydraulic
pumps too, where some application required more quantity of oil than
what the tractor's pump could deliver. Hope that info helps.
