Worn WD Lower Steering Shaft Support |
Post Reply |
Author | ||
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1989 |
Thanks(1)
Posted: 22 May 2021 at 9:14am |
What are folks doing to deal with worn lower steering shaft supports? I am thinking there is not enough material here to re-center/bore out and put a bushing in, like you can do with the support and quadrant on the steering wheel shaft.
I was going to cut off the round portion and weld in a piece of pipe but after I got the pipe cleaned up there's more play than I'm okay with. The ID is a little big. I might try to get a chunk of DOM tubing that would have a tighter ID on that 1" shaft? Any other ideas?
Sponsored Links | ||
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8282 |
One option may be to get a good used one? I am sure they are out there. Maybe someone is parting out a tractor? I dont think I have a extra but will try to look.
You might find a piece of pipe or tubing and cut the old one off and weld the new one on??
Regards, Chris |
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3460 |
They have a grease zerk in them? I wondered what that hole in mine was for.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81175 |
The pipe is probabaly 1-1/16 ID if it is a schedule 40 pipe.. You could cut about a 1/8- 3/16 inch slit in the pipe and PINCH it back together for a tighter fit.. Then weld into place.
Edited by steve(ill) - 22 May 2021 at 6:50pm |
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
How about cutting out the worn section and weld in a section of pipe to match
Wink I am a Russian Bot |
wjohn
Ha! Might as well have not been there on my tractor since nobody seems to have greased it.
wjohn
I hadn't thought about cutting and pinching the pipe I have, then rewelding. I like that idea. I cut a piece to the right length and planned on welding it in place of the existing support. Then I cleaned up the weld seam inside and test fit it on the shaft, and that's when I discovered that it was still a little too loose for my liking.
I didn't want to cut the existing support yet in case someone has a better way of saving the part, and I didn't have the right ID pipe to weld in place yet... But pinching it down should work. I have to imagine a lot of these never got greased and are pretty worn? Mine may be worse than most of them, though.
wjohn
I did get a package of new zerks and nuts with matching threads, so I can drill a hole and weld the nut in so the new part will still have a zerk.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3729 |
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1968 |
I have a bin full of those that are in better condition and also new shafts. Both wear into each other. Now that your package is on its way. The WC used a solid block.
wjohn
That's my fault for not even thinking to ask. Maybe I was wrong in assuming all the used ones are worn. I did weld my shaft up and worked it back to being reasonably round.
JTOOL
Silver Level Access Joined: 28 Feb 2021 Location: 64720 Points: 346 |
When installed does the zerk face down? If so, how did it wear like it did?
Post Reply | |
