Woods question |
Baxter
Joined: 29 Jan 2019 Location: Galena, I'll. Points: 6 |
Topic: Woods questionPosted: 31 Jan 2019 at 11:34am |
Hello everyone. I'm new here. I now with woods mowers mounted on C Allis for many years now. An L306 and 59. I have a friend with a b and was wondering if woods makes the lower tube for the narrower b for the L 306.The telescopic tubes for the no. 59 mower that I have are all for reight turn blades.The b is newer so it has dish wheels so can be set out.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11411 |
Posted: 31 Jan 2019 at 2:51pm |
Go to the wood web site and check
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 31 Jan 2019 at 3:02pm |
Baxter,
Welcome! We need some pictures! Regards, Chris
Joined: 11 Sep 2009 Location: illinois Points: 90844 |
Posted: 31 Jan 2019 at 3:44pm |
Yes........
Baxter
Posted: 31 Jan 2019 at 4:43pm |
Hello again. It is 30 degrees below zero here. The tractor is a simple B with hydraulic that works. 1953 so a C engine. I have worked with L306, 59 and L59 mowers but have never seen the mounting tube for a B for a left turn mower because they are solid where my 59 tube is telescopic so I think would work on either tractor but is for right turn blades. Thank you all for your help.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 31 Jan 2019 at 5:21pm |
The adjustable (telescopic) will work for both. It is how you thread the belt on the mower that makes the difference between the right or left hand cut.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 31 Jan 2019 at 5:28pm |
Yep, its just a twist, one way or the other...
CTuckerNWIL
Posted: 31 Jan 2019 at 9:33pm |
What Dick said. I had the 3 piece push bar on a Woods and could run it either way. You can go buy a new single piece bar and it will have the exact same configuration of the idler pulleys as the 3 piece bar.
You route the belt different, to get right or left rotation of the spindles. Edited by CTuckerNWIL - 31 Jan 2019 at 9:35pm |
Baxter
Posted: 01 Feb 2019 at 4:59am |
Thank you everyone for your help. I am new here and already am having a great experience. You guys rock!
MikeinLcoMo
Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
Posted: 01 Feb 2019 at 8:59am |
I have a Woods tube painted P.O.#1 with no pulleys I'd like to get it out from under my feet. One piece tube.
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
Baxter
Posted: 01 Feb 2019 at 9:44am |
Hi Mike. Thank you for the post. Where are you located?
MikeinLcoMo
Posted: 02 Feb 2019 at 8:43am |
South central Missouri.
Baxter
Posted: 02 Feb 2019 at 10:28am |
Probably not cost effective for me to try to get it. Thank you for posting.
