Woods Mower on a D12
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: Woods Mower on a D12
    Posted: 08 May 2010 at 8:34am
Has anyone mounted a Woods L306L mower under an Allis D12? My lawn mower CA with the Woods L306 mower developed a serious illness (slipping hand clutch) and cannot handle its lawn mowing tasks until I can get it into the shop and I was wondering what it would take to mount the Woods mower under one of my Series I D12's for the season (or beyond). Pictures and other technical advice would be helpful.
Thanks in advance
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:28pm
Usually you need the brackets to fit the tractor. You also have to make sure it turns the correct way. The L stands for Left turning blades.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:47pm
Check with Woods they may have Mounting Brackets in stock.
Also, remember that if this is an early D-12 it does not have live PTO.  The mower blades could have the tendency to "drag" the D-12.
Good Luck!
Bill Long
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:05pm
  ca drives from belt pulley  d-12 from pto with a large pulley for one brackets are different also  woods has also dropped some of the mounting kits   call 1-574-342-4545 for more info.  sold our d-12 at auction in 05 like yours
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 7:06pm
here is one for sale on tractorhouse.  Lots of pictures to look at. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5410238
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:23am
Thanks for the photo and reference for a Woods mower setup on a D12, it is a really different setup than what is on the CA!
The D12 I have has a flat belt pulley on the pumkin just like a CA and the distance between the finals measures the same as my CA. Am going to attempt mounting the woods mower and V-belt pulley from the CA unto the D12 as it appears that the rear support will bolt up to the finals and the flat belt pulley can be replaced with the V-belt pulley from the CA. Will need to figure out a way to raise the deck.
A picture of the rear of my D12 with flat belt pulley:
Picture of the rear mount/pulley on the CA
I will lose the draw bar on the D12 as the lift arms on the CA are different. Will update the ppost after I get the mower mounted.
This page was generated in 0.081 seconds.
