Wiring
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: Wiring
    Posted: 15 Oct 2010 at 11:25am
Hi agine just need wiring digram on WD 45 with 12 volt generator and 12 voltage VR . Well useing the oli light switch . the points coil and light all have been change THATS ALL
Thank You
Rod IN MN
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:42pm
this is a site that tell you a
lot about generator and regulator
http://www.ytmag.com/articles/artint4.htm
HTH
   B:-)     Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:48pm
The original light switch is a resistor switch which works with the cut out relay in the original 6v pos ground set-up. If you are going to 12v with a regulator, ditch the resistor switch for a simple 2 place on off switch. I seriously doubt you will find any diagram of a 12 volt genny and V regulator showing the 3 position switch since it is made to control the cut out relay which you don't have anymore.
Edited by CTuckerNWIL - 15 Oct 2010 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2010 at 7:51pm
or this one depanded on what generator
you have
http://www.ytmag.com/articles/artint29.htm
  B:-)     Dnoym
This page was generated in 0.126 seconds.
