Winter projects |
Page 12> |
Author | ||
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2034 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Dec 2017 at 6:44pm |
Decided to rebuild all my headlights on my tractors. Now that the reflectors, gasket, and other parts are available, it makes a nice light when finished.
Got 16 done. I think I am almost half done with the early tractors before 1960. I will see how this goes before I start on the later ones. How is your project going? ![]() ![]() ![]() ![]() Edited by Lon(MN) - 25 Dec 2017 at 7:21am |
Sponsored Links | ||
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24704 |
Wife flooded the basement AGAIN.... don't ask...
Oh yeah... next Monday is Xmas...just found that out... basement might be dry by then... Jay |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87936 |
Lon , how about a couple pictures and parts list of what you used for the pre 1960s ?
I can take some pictures, but don't know how to post them on here. I can email them to someone if they are willing to post.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5236 |
Well, the 190 XT is finished up. I received my rebuilt hydraulic pump back from Sandy lake. Bill did an awesome job as I finally have 1 finger steering at all engine speeds. It’s been needed since I bought it 1 1/2 years ago. Merry Christmas to me|
Still have to put dads 6060 clutch in fresh back from Rick. Then the 390 AC haybine with Tiger teeth install. Go over the bailer to get ready for hay season.. the Oliver planter needs some TLC. Life as a farmer full time or part time never ends. And I love it| |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
Still working on my grandpa's 1951 Chevy 2 ton truck overhaul...school's out now for a month, so maybe I'll get it finished before too long!
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
Drained 2.5 gallons of antifreeze out of the oil pan of my new project 7040 Powershift, threw two batteries on her, cranked, got pickup on it to jump start, crank more, not much smoke, investigate dangling wires, hook lift pump back up (has the updated dual spin-on filter lift pump kit) crank and she fires up!
Drove it off the truck! Powershift seems crisp! :) Now I need to find out where this antifreeze leak is coming from... :) I am also figuring out why my 2-155 White project will not shift into two gears. I am afraid its a rusted shift collar internally, but I may get lucky and find its just in the linkage. I feel bad about that one, turns out the jockey that sold it powerwashed it and didnt realize it had a cracked manifold, and got water down the engine. Had I known this I would have tried to make it run the day I bought it, but no, harvest was coming and the auction yard I bought it at is very easy to deal with, so it sat till early december. She definitely had some rust in the bores... took starter and muffler off, poured oil down exhaust, barred it over back and forth till I could roll it over, rolled it over 10 times, re-installed starter, and cranked a few times, and she fired up. hopefully the rings are OK... Tuesday I am going after my 6000 series 8 row White planter. Its set on 36 inch rows, and I have not convinced myself that here in dry western KS I need to be on 30s, so who knows, it may stay as-is, or it get scooted in to 8R30. You know you are a junk hoarder when you buy the parts before you buy the tractor, I had the front weights I needed for the White 2-155, top link and quick hitch I needed for the 7040, and many bearings and other things I needed for the 6108 White Planter all bought at auction in years past. we wont even go into the pickup truck projects I have lined up as well... :/ If I get 1 tractor and 1 pickup going and plant 36 inch row corn next year I will be ahead of schedule..... ;) |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
dt1050 ![]() Orange Level ![]() Joined: 05 Jul 2011 Location: central pa Points: 1078 |
waiting for parts to rebuild the d14 lift cylinder, broke 2 wheel bolts off on the d17, spent most of the day laying in the snow drilling them out. hoping for a better day today...lol
drobCA ![]() Orange Level ![]() ![]() Joined: 20 Jun 2017 Location: Perris, CA Points: 292 |
it's amazing to see how much debris a pack rat can accumulate on 5 acres over 20 years.
so this winter is 75% reorganizing "stuff" and 25% trying to get delayed & half finished projects done - one-at-a-time! a new pole barn 2nd shop for woodworking will help considerably. so does being newly retired.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
theropod ![]() Orange Level ![]() ![]() Joined: 28 Sep 2017 Location: Arkansas USA Points: 217 |
Taking my B to a media blasting outfit in mid January that will also apply an epoxy primer used on the inside of steel water towers/tanks. Have a local body shop all set to paint the drive train afterwards. Drain, flush and refill the transmission and differential. New rims and tires all around and the sheet metal reinstalled. By late spring I hope to have my 38 rolling and dressed for the dance.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200 No private messages: use email: theropod AT yahoo DOT com |
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Right now I have an 8010 in the shop that we got last spring. It’s got a new floor mat, cab kit, door seals, radio and speakers, and waiting on a head liner. It had a stiff range shifter and a new cable fixed that. Also ran the GPS receiver cable up the left cab post and out behind the lights so that it’s not exposed to tree limbs and blowing in the wind.
It had a dash throttle so I bought a console throttle from a salvage yard and I discovered some brackets in the cab where the cable and lower bell crank mount we’re missing so I fabbed them up and welded them on. I have some pics I’ll post later. I also noticed that our 85 8070 has the seat mounted 3” lower than the 8050 and this 8010 which works a lot better with an air ride seat. so I had 3/16 metal bent like the 8070. I got it and a grammar air ride seat installed yesterday. It’s been a lot of work but it should be nice planting this spring. 8050 radiator was leaking this summer mowing hay so it’s coming in next. It will probably get recored. It is getting a new radio and head liner while I have it in the shop. Still had the original radio and it doesn’t Work very well any more. It has an air ride seat now but it’s getting lowered like the 8010. There’s a few other od jobs but that should keep me busy for a while. Edited by wekracer - 18 Dec 2017 at 6:22am |
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
I worked on my excel spreadsheet for off season maintenance last night. Only 41 jobs on it ugh.
BEK ![]() Silver Level ![]() Joined: 05 Nov 2017 Location: Wilmington, NC Points: 216 |
Install new bushings in the front axle of the B. Clean and reseal the fuel tank on the WC.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
I am hoping to go 100% through my 385 planter this winter. I haven't used it for the last two seasons, and it's been sitting outside. It'll need some attention. If the cards really fall in my favor, I'll get my 7580 going also, to put in front of it. Darrel
I have to hand it to you Victory, having your jobs on the spread sheet is a good management tool. I wish I had the gumption, or whatever it takes to do that. Seems like when I go to run a seasonal piece of equipment, that's when I remember what I was supposed to fix on it during the off season. Darrel |
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1491 |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1927 |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Wink I am a Russian Bot |
Not a bad idea Dan simple and cheap. Mice probably eat mine. |
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
I've got a chalk board on the wall in the shop. Problem is some of the things listed on it have been there for 10 or more years. Maybe I should just erase it and start fresh....
Allis Express participant |
I've been thinking about doing that...getting a chalk board to keep track of things. But I'd probably be in the same boat...some things stay there for several years!
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5601 |
water pumps on 8070's
rear lights on 8070 throttle cable on 8070's wiper switch on 8050 stadium lights on 7080 UC radiator and belt Uncle Ken's WC Shoot lots of pool
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
My first objective is to stay warm!! Everything after that is gravy......
I HAVE to get carb kits for the WD45, one for a D-17 and the CA. So it'll be boiling them (Dick L's recipe), cleaning, clearing and then new parts. Other than that, I can't get much done,,,,,,I don't have a heated shop/garage as yet. |
Fix major leak coming from hydro area on L2 and install new raddle chains, reroute electrical cables to cab and better seal up cab from mice.
On the corn head, rebuild stripper plates and reverse snapping roll flutes, new drive chains, gathering chains and sprockets. Get my 1616H mower running that hasn't run in over a year. Think key switch of something, no spark. Put led lights on 7050. Not sure on order of things and am pretty sure not all will get done. |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54157 |
Not A-C related, But I gots a new set of skins ordered fer the newest K'boter, gotta pickup the Dixie chopper from the shop, later this week, and gots a payin garden tillin job, tomorrow...
Spent the warm weather yesterday and today, bush hoggin the unfarmed steepest hill on the farm. Today, was 3-1/2 hrs stump grindin about a thousand little gum tree stumps, leftover from the bush hoggin...
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Figured I would work on something a little newer rather than the Model T's this winter so I'm building an old school hotrod like they would have in the 50's from the ground up with scavenged parts. Model A frame and suspension dropped 4" with a 1930 Model A coupe body. Rearend, steering sector and tranny from a 1947 F1 pickup. Front end from a 1939 donor. Hydraulic brakes. 1949 Mercury flathead V8. Some assembly required.
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2191 |
Put as much sand on the groung as mother nature will let me as I'm a dredge operator 6 days a week, and I help at the farm the other 7. My neighbor from 40 years ago has a early 190 gasser, with a junk cab. ( I remember the tractor as a teenager) He want's me to add a second remote and install a loader. The cab isn't going back on. Dad has completely rebuilt 4 rows on the 630 corn head for the L3, the snap roller bearings went out on the other 2 rows this past fall. Lots of little stuff, 4 rears on the 8070, it all takes time. Like everybody else, seems like there is always something I should be doing. My son has his FFA mechanics project too.
Hey Lonn, get some cats and leave the cab door open, many a morning we go the shed and a cat is sitting on the seat. CAT FOOD IS CHEAP. Leon B MO
Edited by Leon B MO - 19 Dec 2017 at 8:26pm |
DaveCinIN ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Kouts, IN Points: 629 |
Well, my projects include but not limited to:
Repair the flashers on the 7045. Repair a hydraulic leak on the 7045. I'm getting close to having the XT with an L combine engine operational, waiting for a few parts that are on order and I need to drop the steering cylinder down an inch. Make some repairs on the Hesston discbine and New Idea hay rake.
AC 7045
AC 190XT with Gleaner L engine Hesston, New Holland and New Idea hay equipment OK, so what's the speed of dark? |
Reindeer ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |
Winter projects....
D15 - weld up seat frame holes that are wallered out, all the pins have worn through the bushings and cut into the frame, and install new bushings -new seal on PTO, and lower seal on power steering shaft -replace all gauges and switches -rewire tractor (new harness is here but need to get into it) -replace valve cover gasket -drive out brake cross shaft, lube up and reinstall, check brake settings -remove heat shield on side of transmission, straighten and clean -replace right fender and straighten brace -remount hydraulic quick connects so they will work -change seat -new tires and rear rims -various cosmetic improvements -sand blast and paint etc. 5015 -valve cover replacement -find engine oil leak and fix -new blades on mower And if there is any thing left by spring, I can work on it next winter.... |
davh ![]() Silver Level ![]() ![]() Joined: 27 Apr 2016 Location: Kansas Points: 117 |
Need to look into my B with the loader. Starts good, runs good, but shoots oil out the exhaust. Not quite sure what I will find, hope it's not too bad.
Page 12> |
