Will combine 2800 work in a 185 |
ryanschott
Topic: Will combine 2800 work in a 185Posted: 10 hours 55 minutes ago at 5:51pm |
I got a 185 that sent the rod thru the side of the block have Chance to get an engine out of a combine. Will it work I’ve heard they have longer crank snout. Is that true any other things that would need to be fixed or changed
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2480 |
Posted: 10 hours 4 minutes ago at 6:42pm |
There's a lot of variations in those engines. If it's a 2800 series from an F or early F2 combine, it would come close. Cam or crank driven oil pump is one thing to be considered. Front plate for the hydraulic pump is another.
Posted: 9 hours 29 minutes ago at 7:17pm |
What year or serial number is the tractor??? Makes a difference on which oil pan it can have. What year and model of combine is the donor engine coming from ??
ryanschott
Posted: 9 hours 6 minutes ago at 7:40pm |
1978 185 combine was in junkyard and they drove it in said motors good but combine gone and they don’t remember anything about it
Posted: 8 hours 28 minutes ago at 8:18pm |
1978 185 would have the crankshaft driven oil pump with the deep oil pan. Combine engine turbocharged or not ??
Lynn Marshall
Posted: 6 hours 53 minutes ago at 9:53pm |
The original post mentions a 2800 combine engine. I would assume that it's from an F or early F2,and that it's non turboed. But,who knows. Engines get changed and altered over the years. A 6080 engine or one from a later F2 would make for a sweet project.
