Will combine 2800 work in a 185 |
ryanschott
Topic: Will combine 2800 work in a 185Posted: 13 Mar 2026 at 5:51pm |
I got a 185 that sent the rod thru the side of the block have Chance to get an engine out of a combine. Will it work I’ve heard they have longer crank snout. Is that true any other things that would need to be fixed or changed
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 13 Mar 2026 at 6:42pm |
There's a lot of variations in those engines. If it's a 2800 series from an F or early F2 combine, it would come close. Cam or crank driven oil pump is one thing to be considered. Front plate for the hydraulic pump is another.
Posted: 13 Mar 2026 at 7:17pm |
What year or serial number is the tractor??? Makes a difference on which oil pan it can have. What year and model of combine is the donor engine coming from ??
ryanschott
Posted: 13 Mar 2026 at 7:40pm |
1978 185 combine was in junkyard and they drove it in said motors good but combine gone and they don’t remember anything about it
Posted: 13 Mar 2026 at 8:18pm |
1978 185 would have the crankshaft driven oil pump with the deep oil pan. Combine engine turbocharged or not ??
Lynn Marshall
Posted: 13 Mar 2026 at 9:53pm |
The original post mentions a 2800 combine engine. I would assume that it's from an F or early F2,and that it's non turboed. But,who knows. Engines get changed and altered over the years. A 6080 engine or one from a later F2 would make for a sweet project.
ryanschott
Posted: 14 Mar 2026 at 8:36am |
No turbo. I have the bad 185 motor so if timing cover different can change
Posted: 14 Mar 2026 at 8:47am |
You will have to change the timing cover and the front plate and probably the oil pan. All combine engines have no place for a hydraulic pump, so those parts must come from your tractor engine. This requires pulling the camshaft and replacing it. Also the water pump from the tractor is required.
ryanschott
Posted: 14 Mar 2026 at 11:28am |
Well new info I just bought a 185 motor for my 185 so should fit. Have to go pick it up in two weeks said it’s out of tractor that ran good but rear end was bad I do have to use my injection pump and hydro pump. Probably the best solution
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 14 Mar 2026 at 11:57am |
'They said' is a pig in a poke, but yes, if it is good runner it will save a couple or three days labor.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 15 Mar 2026 at 7:29am |
I have two generator engines; a 2800 (non-turbo) and a 2900 (turbo). Both have the mounting bracket for a hydraulic pump.
I would sell one.
