Wide front C to a CA?
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Topic: Wide front C to a CA?
    Posted: 15 Jul 2010 at 6:31pm
A friend asked me if a wide front from a C is the same as a CA wide front. I didn't have a good answer but i'm bettin someone on here knows.
Thanks. Bob@allisdowneast
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 6:50pm
It's not the same. It will however bolt on. If you put a C front on you won't be able to mount any frount mounted implement. the mounting boss's are differant. the Axle center section is slightly differant. The fount bolster for a CA has reinforcments cast in that are not on a C front.  You will want the C grill to go with the front end .
Onemeanc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onemeanc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 6:52pm
I do believe a CA has a taller spindle assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onemeanc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 7:10pm
Dakota Dave  has all the bases covered !
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 1:38am
Here is a exploded view.
I know what Dave means but technically he is not correct. The wide front can be put on without changing the bolster. The bolster is a seperate piece of the tractor. Dimensionally both wide fronts are the same. The CA spindles has stops cast on the bottom of it. The center sections also have different part nos. because they are welded together diferently.
Edited by Nathan (SD) - 16 Jul 2010 at 1:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 10:38am
Thanks, everyone. I will pass this on. Bob
This page was generated in 0.150 seconds.
