wheelybars
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: wheelybars
    Posted: 20 Apr 2015 at 1:41pm
Can u guys share some pictures of wheelbars for a 190 or 200. I was just informed that all tractors got to have them to pull with my club due to inserence reasons. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 8:18am
All depends on how much of your original drawbar and 3 point hitch you are leaving on the tractor. You could attach to the side of the torsion bar framework where the sway blocks attach to, if that stuff is still there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 11:07am
Well I have the pto and the drawbar but no 3point arms or sway blocks and the drawbar is adjustable
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 12:37pm
Well then, attach to where the sway blocks went. Make sure they extend back as far as the rear tire diameter and no more than 9 inches off the ground and capable of supporting the weight of the tractor. Maybe make them adjustable in height for loading/unloading from a trailer.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 8:20pm
If you will send me your email I can send you some pics of mine that I have on my phone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2015 at 8:46pm
Sent u a pm 2wise4agm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2015 at 4:43pm
[/IMG]
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2015 at 8:13pm
A question for 2wise4agm: Are the u-bolt axle hubs AC specific/ or will another tractor  brand work on the AC axle?  I am not having any luck finding a set and I prefer not to weld on a 9 bolt hub and cut off axle stub.  Thanks
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2015 at 8:17pm
I found my hubs and wheels in a salvage yard. They are not AC specific. Don't remember who mine are made by, but they are aftermarket.
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 12:36am
Beirnsy what part of the country are you in I have one good one and one that I tore the key off mine were dmi brand.i have been told it is repairable. I switched too weldonhubs. Also I was told Oliver used a lot of that size hub not sure if that's true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2015 at 5:06pm
I am in SW Ontario,  I have thought of the Oliver style, the Oliver keyway is tapered. My Oliver collecting neighbours say I could grind keyway square.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2015 at 5:39am
Check these guys out. Real nice stuff
http://www.capbrosmotorsports.com/index.html
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
