What's your towing rig?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: What's your towing rig?
    Posted: 04 Mar 2012 at 12:57pm
And what do you tow with it for weight?   For my tractor hauling, I started out with a Chevy 1500 with a 18' 12000 lb. trailer but the biggest I had ever hauled was a D17 with that setup.   I now have an 02 Ford F250 with the 7.3 powerstroke and am looking at upgrading my trailer to a gooseneck, mainly because my D19 doesn't fit on the current trailer that well.   Was wondering what you all have for towing rigs, and trailers and/or what you would recommend.   I don't want to go too big, but if I'm upgrading to a gooseneck, I would like to go a little longer and make sure it's a 8' wide deckover for wider tractors, etc.   I have found a couple used 12000 and 14000 lb. gooseneck trailers and would like to know if that's fine, or do I need to be going heavier.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 1:16pm
I currently have an 04, F350, with a 6.3L Powerstroke dually, always use cetane booster and Ford oil filters.  The truck is licensed for 24K, so I ordered the trailer with two 7K axels.  With the weight of the truck and trailer I can only legally haul around 14K so I opted not to spend the money for the 10K axels and all that extra rubber.  I am considering upgrading to a small Freightliner with a small living quarters, gooseneck hitch and an enclosed gooseneck trailer.  Put RV tags on it and travel until D.O.T. finds a way to stop that.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 1:35pm
I tow with a 97 F-Superduty (pre 450) 7.3 DIT with lots of  mechanical and computer grades, it is as much a toy as my tractors are.  It will easily pull, and stop anything that should be hauled on my 18' 14,000 GVW gooseneck trailer.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 1:35pm
I started with a old body style dodge that had a cummins in it and a  24k lb gooseneck dual wheel tandem axle. Problem with the dodge it was three wheel drag, once you got off the blacktop you might need to unload the tractor and drag the truck to solid ground(actually been there and done that). Truck would pull great on solid ground, hauled a 8070 fwa with loaded tires one day no problems. Now i have the same trailer but pull it with a 2500 chevrolet 4x4 with a 6.0 gas engine and a 5 speed. Its a bit of a dog compared to the dodge but will go off road and is paid for. I believe if the combination truck and trailer is plated over 26K you by law should have a CDL license. The 14K trailer should be fine hauling most tractors below 100 HP i would think. A D-21 or something bigger would tax your tires pretty good especially on a hot summer day on a longer haul. The 7.3's are the most reliable powerstrokes out there, always thought the Fords had a nice comfortable interior. I personally really like the gooseneck over a bumper hitch they just seem to pull better and you dont have the stupid wheel wells to try and fit between.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 1:58pm
We still go oldstyle around here. 1995 chevy 3500 pickup/ 6.5 diesel. 14000 lb. 18ft bumper. It will get you there, just not very fast loaded. Real good on fuel and not alot invested. A good farmtruck..
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:10pm
 Tim
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:20pm
04 Super duty with V10 the trailer is custom built by local trailer manufacture 20 ft with a 4 ft beaver tail that can flip up to give me up to 24 ft of deck running 3 7K axles under it.  A trailer with triple singles with pull easier than tandem duals.  After having goosenecks I will never buy a bumper pull of any decent size.  I used to bum and barrow trailers then one day the wife said either you are going to order a trailer or I will do for you so I made the call and ordered what I got.  I made sure that when I ordered to make sure I did it right so it wil be a long term trailer.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:23pm
If it is bigger than my D 15 II, I just use this !!!
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:39pm
2007 Dodge 3500 - Cummins - PJ 14,000 lb, - 21' Deckover
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:45pm
Chuck, I pull with a 95 7.3 long bed crew 4x4. My gooseneck is a 16 flat/4 dovetail 101 wide. It has 2 7,000 lb axles de-rated to 10,000 by the company I got it from to stay under 26,000 total. My heaviest load is my UC @ about 6,800 lbs. Trailer weights 3,500 so I'm in trouble if I hit the scales. Pulls like a million bucks though!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:53pm
1997 GMC 3500 4X4 WITH 454; AND 22ft GN.[trailerman] the bigest thing i haul is the 190XT or 300 bails of hay.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:05pm
I have my 1995 E350with a 7.3 but haven't towed anything with it yet. I need the hitch first. All I have for a trailer is a 7K car hauler but I did drag my OC46 home on that. No counter weights and no loader and I was still making my trailer strain with that load:(
 When I find me a "new" trailer it will most likely have a pintle hitch and be at least 10K.
Edited by CTuckerNWIL - 04 Mar 2012 at 3:09pm
70Standard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:16pm
I pull with a 2002 Ford F250 regular cab 4x4 with a 7.3 liter diesel that has been amped up a bit with hardware and electronics.  My trailer is a 23' deckover (including 4' beaver tail) with two 7k axles, both with brakes.
After studying what I planned to haul, the weight of my truck, the truck's GCVW rating and the weight of the trailers, I bought my trailer with a ball hitch rather than a gooseneck.  It weighs in at 3,800 pounds.  I had to buy a much heavier receiver hitch that was rated for 15,000 pounds (factory unit was rated for 6,000 pounds).  Depending on the manufacturer, the gooseneck adds 500 to 1,000 pounds of weight to an otherwise equivalent trailer.
I see a lot of guys driving 3/4 and one ton trucks pulling gooseneck trailers with tandem axles and duals - probably 20,000 pound rated trailers.  While I'm sure they've got plenty of pulling power, the GCWR (weight of truck, trailer and all payload) is typically only 20,000 or 21,000 pounds for a 3/4 or one ton truck.  If you do the math, they have paid for a lot more trailer than they can legally pull.  That's fine until they load up the trailer that puts their GCWR over their truck's limit, and DOT pulls them over or they get into an accident.
If GCWR wasn't an issue, I would have bought a gooseneck in a heartbeat.
Edited by 70Standard - 04 Mar 2012 at 3:18pm
Roof Palomino (SN 224), Chetech Pug UTV, Three Green Tractors and one Red Tractor.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:19pm
I recently purchased a 32 ft long by 8ft6in wide tarnel gooseneck with tandem duals/10 K axles. I can pull it with the pick-up, but most of the time it goes quite sweetly behind my 93 freightliner FLD 120. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:20pm
'99 F250 SD with 7.3 set to +75 hp by programmer.  12mpg all day with the 180 and bush hog on it.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:22pm
I just bought a truck Friday. 1997 F250 HD 7.3L Powerstroke 4X4 crew cab. I'll use my 18 ft. bumper pull trailer for now. The heaviest I haul is my WD45.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:26pm
04  Dodge Cummins with a PJ 22' bumper pull.  I originally bought the dually and bumper pull so I could use my Lance 8.5 camper and still pull a heavy trailer to shows....that only happened a couple of times, but I am satisfied with the setup. I agree that a gooseneck is normally overkill....and with a dually becomes a DOT magnet. Add tandem duals to the trailer and you have more weight in the truck and trailer than what you can haul...
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:31pm
Like your trailer Eldon! Oh, the truck ain't bad either:)
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 4:15pm
Small rig is a 2011 GMC 2500 HD Duramax with 20+5' Featherlite gooseneck with 2 7K axles. GCW 11,000 KG (24,3000 lbs). Big rig is a 1997 Ford Aeromax with a 53' Wabash step deck tridem with a beavertail and flip up ramps (104,000 GCW). Luckily I need these for our business.
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 5:14pm
Right now my 92 Dodge cummins with a 7000lbs trailor for the small stuff looking for a 14000 lbs goosneck deck over for our bigger stuff.
                        Brandon Doyle
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 5:20pm
95-F-350 CC 4X4 powerstroke, auto with 410 gears and a 20+5 Moritz F-neck tandem dual 19.5 k low pro trailer.  My empty weight is around 14200 somewhere.  I have pulled onto the scales at the equity with the neighbors Donahue grain trailer and a load of corn weighing 34900.  Don't do that anymore since they have a semi
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 5:49pm
we use this to haul the d19 and the wdand this is my brothers he hauls his d17 and his daughters d15
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:20pm
I have a 2000 F-250 with a 7.3 powerstroke with 357,000 miles on it and a 24 ft gooseneck with approx 300,000 miles on it and it has 2 7,000# axles this rig has been in 46 of the 48 continental US. I just recently upgraded the truck to a 2002 F-350 dually. I have hauled a lot of units in the past ten years, some for people on this forum.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:53pm
I have a Chev 2500 with the 8.1 and the allison transmission, and a 20+5 gooseneck trailer with 2 7000lb axles, it is a good combination.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:01pm
i have a 02 gmc duramax  with a 90 hp chip and a 20+4 goose neck gvw is 26000 the heavest i have hauled is my 7045 at 16000  i know its illegal sorry  shawn
190XT,D17and 7045
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:06pm
In October I replaced my 93 cummins 350 daully with an 2011 cummins 4500 4x4 with 6 speed auto and 9ft dump,has Jake brake.Can pull 30ft 10ton trailer with 8 ton excavator and have never driven a rig that is so much of a pleasure to drive with a trailer behind it.For my big loads I have a 05 IH tri-axle that I pull a 36ft 15ton trailer that has a 330hp IH powerplant.
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:14pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:25pm
GMC Yukon Denali with the 6.2L motor. Pulls and stops real good.
16' trailer loaded with the D-17 doesn't seem like much behind it.
Charlie
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:30pm
06 chevy 2500HD Duramax with a 28' dual tandem GN 22k gvw.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:33pm
If I were a rich man it would be this.
