What's wrong with my fescue sample?? |
Bradleytrench
Topic: What's wrong with my fescue sample??Posted: 26 Jun 2019 at 10:33am |
Took my A2 to the field after finishing getting it switched over from beans to fescue. Which is changing the cylinder drive sproket, putting concave bars back in. Found a bearing about to go out. Replaced it. Closed the cieve and shoe down. I was cutting in 1st gear. Dad made me speed up to 2nd gear full variable speed and this was the sample.
1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 26 Jun 2019 at 12:01pm |
I know Bob thought the old man had lost his mind helping him with in-field setting the old AII to cut fescue and then I said to keep speeding up he had to be thinking now the old man is just trying to plug the cylinder. lol Now all Bob needs to make the job go faster is to find a 16' head (over the 14' he now has on it) so he can get over more ground in a day. I know Bob was happy to hear the big farmer next door to the field he was cutting said that was a better sample than his much newer John Deere puts in his grain tank. It's nice to see a 50+year old combine work so good!
GOOD JOB Bobby!
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 26 Jun 2019 at 12:15pm |
Looks like an excellent sample to me . The 60's all crops where good grass machines also
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 26 Jun 2019 at 6:58pm |
In my "mind", it just seems bass ackward to clean-up a sample with increased ground speed
. 2 seasons ago I posted our dilemma with dirty soy sample in the F2, consensus was to drive faster LOL!!
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 26 Jun 2019 at 7:09pm |
Combines work best at capacity. Drive faster puts more through it at a constant RPM. At least according to my Stueckle book.
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9467 |
Posted: 26 Jun 2019 at 7:23pm |
About 40 years ago, I worked one year for a guy who sold certified seed. That sample looks like what we put in the bag after it went through the cleaner. Maybe better.
DougG
Posted: 26 Jun 2019 at 7:52pm |
Its clean for sure! The weather is sure playing he'll with it,, at .65 a lb good money in those sticks
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 26 Jun 2019 at 9:17pm |
Bobby, Now I am not a good judge, but that sure looks like seed that has been across a fanning mill!
Awesome! Sometimes those old dad's do know a thing or two! Glad your showing those big green guys a thing or two also!:) Regards, Chris
Bradleytrench
Posted: 26 Jun 2019 at 11:07pm |
Thanks for all the responses. Was going to move to another field and cut but mother nature has decided to blow it all out.
So i guess ill switch over to wheat and go cut wheat. Which is just a few minor adjustments akd off i will go. Bobby Mo |
Unit3
Posted: 27 Jun 2019 at 3:56pm |
I think we need some combine pictures too.
CTuckerNWIL
Posted: 27 Jun 2019 at 4:51pm |
FREEDGUY
Posted: 27 Jun 2019 at 5:01pm |
Is the A/A2 a sprocket driven cylinder? Dad ran an "A" up until '92 when he "upgraded" to a straight F with a 4/30 corn head and a 13' platform. The belt drive cylinder threw him for a loop as well as the adjustable fan speed (in cab).
Bradleytrench
Posted: 27 Jun 2019 at 6:33pm |
How about a couple of videos.
https://youtu.be/uDAdFuW5QqQ https://youtu.be/xPAPKlhi5sM Edited by Bradleytrench - 27 Jun 2019 at 6:35pm |
Bradleytrench
Posted: 27 Jun 2019 at 8:11pm |
The A2 (serial number 32000 and up) is both belt and chain driven cylinder. The belt runs from the seperator clutch to a variable speed pulley. The variable speed pulley is adjusted by turning a wheel inside the cab. The variable speed pulley will let you adjust the cylinder speed around 150 to 200 rpm. The variable speed pulley has a #60 chain sprocket attached to it. The cylinder has a changeable sprocket on it like a straight A. When changing crops, you have to change the driven cylinder sprocket. For fescue, I think its a 22 tooth sprocket I'm running to get around 1250rpm cylinder speed. For lets say soybeans, you would run a 84 tooth sproket to slow it down to around 300rpm. But the variable speed lets you fine tune the thrashing as the day goes. Tenp and humidity change a combine. Today running the fescue I adjusted the sieve and shoe once added some more air buy adjusting the doors on the fans. As the afternoon went on. It clouded up and humidity changed so i cranked on the wheel and speed the cylinder up a little more to do a better job thrashing. I hope it makes since to you. I'm no expert combine operator. I've only had this thing over a year. Bobby MO |
CTuckerNWIL
Posted: 27 Jun 2019 at 8:44pm |
That there looks like you're flyin
![]() [TUBE]xPAPKlhi5sM[/TUBE] |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34640 |
Posted: 28 Jun 2019 at 12:54am |
[TUBE]uDAdFuW5QqQ[/TUBE]
