What's wrong with my fescue sample??
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=162242
Printed Date: 09 Apr 2026 at 7:00pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: What's wrong with my fescue sample??
Posted By: Bradleytrench
Subject: What's wrong with my fescue sample??
Date Posted: 26 Jun 2019 at 10:33am
Took my A2 to the field after finishing getting it switched over from beans to fescue. Which is changing the cylinder drive sproket, putting concave bars back in. Found a bearing about to go out. Replaced it. Closed the cieve and shoe down. I was cutting in 1st gear. Dad made me speed up to 2nd gear full variable speed and this was the sample.
------------- 1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Posted By: Don(MO)
Date Posted: 26 Jun 2019 at 12:01pm
I know Bob thought the old man had lost his mind helping him with in-field setting the old AII to cut fescue and then I said to keep speeding up he had to be thinking now the old man is just trying to plug the cylinder. lol Now all Bob needs to make the job go faster is to find a 16' head (over the 14' he now has on it) so he can get over more ground in a day. I know Bob was happy to hear the big farmer next door to the field he was cutting said that was a better sample than his much newer John Deere puts in his grain tank. It's nice to see a 50+year old combine work so good! GOOD JOB Bobby!
------------- 3 WD45's with power steering,G,D15 fork lift,D19, W-Speed Patrol, "A" Gleaner with a 330 corn head,"66" combine,roto-baler, and lots of Snap Coupler implements to make them work for their keep.
Posted By: festus51
Date Posted: 26 Jun 2019 at 12:15pm
Looks like an excellent sample to me . The 60's all crops where good grass machines also
------------- We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Posted By: FREEDGUY
Date Posted: 26 Jun 2019 at 6:58pm
In my "mind", it just seems bass ackward to clean-up a sample with increased ground speed . 2 seasons ago I posted our dilemma with dirty soy sample in the F2, consensus was to drive faster LOL!!
Posted By: exSW
Date Posted: 26 Jun 2019 at 7:09pm
Combines work best at capacity. Drive faster puts more through it at a constant RPM. At least according to my Stueckle book.
Posted By: modirt
Date Posted: 26 Jun 2019 at 7:23pm
About 40 years ago, I worked one year for a guy who sold certified seed. That sample looks like what we put in the bag after it went through the cleaner. Maybe better.
Posted By: DougG
Date Posted: 26 Jun 2019 at 7:52pm
Its clean for sure! The weather is sure playing he'll with it,, at .65 a lb good money in those sticks
Posted By: Sugarmaker
Date Posted: 26 Jun 2019 at 9:17pm
Bobby, Now I am not a good judge, but that sure looks like seed that has been across a fanning mill! Awesome! Sometimes those old dad's do know a thing or two! Glad your showing those big green guys a thing or two also!:) Regards, Chris
------------- D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Allis F-40 forklift, Allis CA, Allis D14, Ford Jubilee, Many IH Cub Cadets, 32 Ford Dump, 65 Comet, 66 F100.
Date Posted: 26 Jun 2019 at 11:07pm
Thanks for all the responses. Was going to move to another field and cut but mother nature has decided to blow it all out.
So i guess ill switch over to wheat and go cut wheat. Which is just a few minor adjustments akd off i will go. Bobby Mo
Posted By: Unit3
Date Posted: 27 Jun 2019 at 3:56pm
I think we need some combine pictures too.
------------- 2-8070FWA PS/8050PS/7080/7045PS/200/D15-II/2-WD45/WD/3-WC/UC/C
Posted By: CTuckerNWIL
Date Posted: 27 Jun 2019 at 4:51pm
Unit3 wrote:
I think we need some combine pictures too. |
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
Posted By: FREEDGUY
Date Posted: 27 Jun 2019 at 5:01pm
Is the A/A2 a sprocket driven cylinder? Dad ran an "A" up until '92 when he "upgraded" to a straight F with a 4/30 corn head and a 13' platform. The belt drive cylinder threw him for a loop as well as the adjustable fan speed (in cab).
Date Posted: 27 Jun 2019 at 6:33pm
How about a couple of videos. https://youtu.be/uDAdFuW5QqQ" rel="nofollow - https://youtu.be/uDAdFuW5QqQ https://youtu.be/xPAPKlhi5sM" rel="nofollow - https://youtu.be/xPAPKlhi5sM
Date Posted: 27 Jun 2019 at 8:11pm
FREEDGUY wrote:
Is the A/A2 a sprocket driven cylinder? Dad ran an "A" up until '92 when he "upgraded" to a straight F with a 4/30 corn head and a 13' platform. The belt drive cylinder threw him for a loop as well as the adjustable fan speed (in cab). |
The A2 (serial number 32000 and up) is both belt and chain driven cylinder. The belt runs from the seperator clutch to a variable speed pulley. The variable speed pulley is adjusted by turning a wheel inside the cab. The variable speed pulley will let you adjust the cylinder speed around 150 to 200 rpm.
The variable speed pulley has a #60 chain sprocket attached to it. The cylinder has a changeable sprocket on it like a straight A. When changing crops, you have to change the driven cylinder sprocket. For fescue, I think its a 22 tooth sprocket I'm running to get around 1250rpm cylinder speed. For lets say soybeans, you would run a 84 tooth sproket to slow it down to around 300rpm.
But the variable speed lets you fine tune the thrashing as the day goes. Tenp and humidity change a combine.
Today running the fescue I adjusted the sieve and shoe once added some more air buy adjusting the doors on the fans. As the afternoon went on. It clouded up and humidity changed so i cranked on the wheel and speed the cylinder up a little more to do a better job thrashing.
I hope it makes since to you. I'm no expert combine operator. I've only had this thing over a year. Bobby MO
Date Posted: 27 Jun 2019 at 8:44pm
That there looks like you're flyin  [TUBE]xPAPKlhi5sM[/TUBE]
Posted By: JC-WI
Date Posted: 28 Jun 2019 at 12:54am
[TUBE]uDAdFuW5QqQ[/TUBE]
------------- He who says there is no evil has already deceived himself The truth is the truth, sugar coated or not. Trawler II says, "Remember that."
