What's it worth
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Topic: What's it worth
    Posted: 13 Jan 2019 at 1:44pm
What would a freshly rebuilt ca engine be worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 1:56pm
a loaded question !
'rebuilt' ..to what end ? All new sleeves,bearing,dist,carb,???
what was replaced..main bearings back to factory spec ?
'should' be worth 3X parts installed value, maybe..
a LOT depends on whether buyer NEEDS it
If it can be heard running...$1000 ??
Jay
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 2:34pm
I am in the process of doing a B engine (for my steel wheeled, war time B) right now, so I can give you some figures.
My prices:
Sleeve, piston & ring kit - $380
Complete gasket set - $60
Valve train kit - $110
Rod bearings - $65
Main bearings - $100
Shims (rods & mains) $50
There was also some shipping costs on most parts.
My crankshaft (out of a combine engine) miked out perfect with standard bearings, so I had no machining on it.
I don't have a price on just the machine work, since I sent a D-17 head at the same time, but I had the block, head and D-17 head hot tanked, the block decked, head and manifold resurfaced and new valve train installed with new seats, plus the work on the D-17 head and total machine work was $550.
I got all my parts from Jim Danforth at OK Tractor, except the valve assembly and sleeves, pistons and rings that I already had .
My guess is somewhere in the range of $1100, but again, my crankshaft didn't need machining, which saved me some money.
Edited by WF owner - 13 Jan 2019 at 2:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2019 at 2:36pm
That's why I grabbed a C for $600, that was pretty rough, but the engine ran like a top.
