Whats a 920 Diesel worth? |
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Mar 2010 at 7:37pm |
I have a chance to buy a 920 diesel lawn tractor. It has a deck, but no other attachments. Supposedly runs, but sounds like the starter is probably out of it. Thats all I know. It looks pretty decent, tires dont look bad, sheet metal is straight. What is a fair price?
Thanks
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1281 |
I saw one on for sale for $3200 a while ago. I don't know if it ever sold. Only attachment was the mower deck. Better check on the price of that starter before you make a offer. That brand of engine powered the first Concord air seed carts. Last price on those starters was $1700. Only available from Italy. I don't know if the Lawn mower is that bad also.
kip in cny ![]() Orange Level ![]() Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
I bought mine last year for 1500 its the best looking one I ever seen. All it has is a mower deck. Parts are hard and $$$$$ I need a voltage regulator and they are 3 to 500 depends where your looking. But in that shape try a few hunderd and see if they like the offer. kip
160 CA 920diesel 5020 HD-3
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Adam, If it's the one on craigslist, he's advertised it in AR, OK, and MO. $1100 looks high to me. If it were near, and $500, I'd own it, but withhim advertising it that far apart, who knows where it is????
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
Jim - Thats it.
The story is a bit sketchy to me, or I might have to do something about it. When I factor in what Nathan said about the starter price, that probably blows me out of the water as well. Thanks guys!
Byron WC in SW Wi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 1635 |
You can get the starters rebuilt fairly reasonable. I bought one about 12 years ago and had a local electric motor guy rebuild it for something like $50. But, If you can't hear it run it's a little sketchy. I ran mine for awhile on one cylinder. They are loud and tend to smoke quite a bit but that may just be my engine. I'm not sure if you can get parts or not but the engine's are lombardini's.
They used to have a website www.lombardiniusa.com Now when you type that it it directs you to Kohler. I'm not sure what is up with that? Perhaps Kohler bought them out? I see Kohler now offers both liquid and air cooled diesels so maybe the air ones are the lombardinis? |
mnman ![]() Bronze Level ![]() ![]() Joined: 20 Dec 2013 Location: Minnesota Points: 10 |
I live in Minnesota and have an Allis Chalmers 920 Diesel for sale. The only attachment it has is a 48 inch mower deck. It runs but needs some work. I can pictures if you contact me.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Wiggle the connector on the voltage regulator. Mine didn't charge when I got it, but when I checked to see if it was on tight, it started charging. Every once in a while, I have to push it back on, when I notice its not charging. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Is that the one that was in SE Minnesota?? I saw that on Craigslist (and was near me), but I wasn't even interested in looking at it for that price. I bought mine (Simplicity 7790) several years ago for $300 but it was burning oil and smoking bad. An engine tear-down revealed plugged up cooling fins and oil control rings that were smooth as a baby's butt from being run hot. New rings ($200) and a burnish of the cylinders and I was back in business. I have also spent $200 on having the injectors checked and one rebuilt. A good clean gas 917 is maybe worth $600-$900. A 920 in good condition would be worth another $200-$500. The trick is finding one that doesn't need work--------parts are very expensive. |
Mark
What kind of work??? |
Mark
Yes, Kohler either bought them or the distribution rights for North America. |
Mark
It burns some oil and I believe it needs new head gaskets because it looks like it leaks oil out of them.
Matt Tallant ![]() Orange Level ![]() Joined: 15 Aug 2011 Location: Virginia Points: 689 |
People used them to mow with and never cleaned the cooling fins on the engine which caused them to overheat.Very common for them.Garden tractor market is soft right now.There are plenty of them left I wouldnt jump on the first one I see.JMO
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
paid $2500. for mine ona farm sale, only had the mower deck on it, it runs awsum...and Pruitt In Omaha,ne has and can get any parts for them (engine parts in mean) it's a lambardini diesel!
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5030 |
Some of our older arrow boards at work (highway maintenance) had lambardini diesel engines (that ran a generator to charge the batteries). There may be some engines/parts available on some of these since arrowboards have (mostly) been replaced by solar powered variable message boards.
frochevy ![]() Silver Level ![]() Joined: 10 Dec 2012 Location: Kansas Points: 79 |
Hello
I hate to hijack this post but it's a few years old. .. anyhow I'm looking at a 920 on craigslist. The owner removed the diesel and re-powered it with an 18hp kohler gas engine. The mower comes with mower deck, snow blower, and rear tiller as well as the "worn out" original diesel engine and he's asking $650. Is this mower worth that? Thanks |
The attachments are likely worth $500 by themselves. If the hydro and installed engine are OK, it's a good deal.
Be sure to include the "worn out" diesel. The parts on that may be worth the asking price. Better it, it may just need rings. Mine was smoking really bad and using oil when I bought it cheap. A set of rings was all it needed. Edited by 427435 - 14 Sep 2015 at 10:09pm |
Mark
Thank you for the info. Going to try and go look at it tomorrow evening.
Did you buy it? |
Mark
sorry I miss spelled the name of the engine, its: lombardini.
