what oil for wd45 trans?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: what oil for wd45 trans?
    Posted: 13 Mar 2011 at 11:52am
Trans- hydro?
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 12:59pm
Others have used that with no problems.Mine has had 80-90WT for 30 years.Some use hy-tran in hyd & trans on 45's with no problems.That's the direction I'm going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 1:30pm
I put hy-tran in both the hydraulics and the tranny, differential in my 45 because I had heard about gasket failures allowing the fluids to mix. I first did this about 29 years ago when I replaced 3rd gear.
Edited by CTuckerNWIL - 13 Mar 2011 at 1:31pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 2:25pm
I have 80W90 in the differential. and HYtrans in the Hyd and hand clutch. This works out nicely it don't get any creep with the hand clutch disengaged. The gear oil stops the trans gears enough that I can shift with just the hand clutch once I come to a complete stop.
This page was generated in 0.093 seconds.
