What kind of oil for the Power Director? |
Morpar55 ![]() Bronze Level ![]() ![]() Joined: 01 Nov 2021 Location: Indiana Points: 116 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jun 2022 at 3:26pm |
While I am going through and changing the fluids in my tractor I found a drain plug I hadn't seen before. When I checked my manual I found it was for the Power Director and since I know I never have changed it I figured it was probably due. Well draining it out went easy, but what do I put back in it? The manual says it can use SAE 20W/20, 80 EP, or automatic transmission oil type "A" and to ask the tractor owner or operator what type of oil has been used. Great. Clear as mud! I have never heard of a 20W/20 oil or type "A" ATF and I'm not sure what 80 EP is (maybe like 80W90 gear oil?) So I am at the mercy of this group for recommendations as to what to put back into my tractor.
1959 AC D17 Gas with some updates
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24715 |
I've used 'Universal Tractor Fluid' or whatever 'they ' call it for every hole in my D-14s( cept engine) for past 2 decades. 'cheap' stuff from Wallmart...never had any issues....
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88080 |
YEP... Hytrans, UTF, Trans/ Hydraulic fluid... whatever you want to call it.. Same as in the hydraulics.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8645 |
Yes,the one for hydraulic and transmission and usually includes wet brakes. Allis called it 821 power fluid. Using it in WD45 torque tube and trans for years.
