what is this lever on this WC
J. Barefoot/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J. Barefoot/NC Quote  Post ReplyReply Direct Link To This Post Topic: what is this lever on this WC
    Posted: 22 Nov 2010 at 9:56pm
Hello, I just purchased a W speed patrol. There is a gear stick type leaver at the rear of the tranmission. If I move this lever to the rear with the tractor in gear it stops or stops the transmisson from powering the rear end.  new to a WC. Thanks for any advise or help on this.  It is a 1940 by the serial number on the plate of the front ext.   1E 306
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2010 at 10:11pm
Cultivator disconnect.  Used to let the mechanical lift work without the tractor moving.  The unstyled WC's didn't have that and since the cult lift worked off of the utput shaft of the tranny, the tractor had to be moving for the lift to operate.
AaronSEIA
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 4:34am
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:19pm
Could you look on the center of the rearend on the back side and tell me what the Tractor No. is ? The front tag is missing on my 1940 and I'm trying to narrow down the # on mine.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:34pm
Kinda strange they would have a disconnect on a speed patrol????
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 7:40pm
Both of mine have one. 1940 and 1949.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 12:37am
I've got a '37 that's got one... and the mechanical cultivator lift... ??
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 5:15am
If you need to lift the blade maybe but can't move the tractor like up against a building or something? I don't know what lifts the blade so I'm just guessing.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 5:35am
Not sure about a cultivator lift but I would guess the rearend disconnect was used when towing the grader from place to place, wouldn't have to worry about the tranny shifter bouncing into gear.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 10:43am
Remember that the base for the W road patrol is a standard WC tractor.  That included the rear end disconnect.
Good Luck!
Bill long
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 5:18pm
on my w patrol , I use the disconnect when I tow it to local show & parades. It won't fit on my trailer with the blade on it, so I tow it. I was thinking the disconnect was an option on the WC's, don't know for sure but I have another w patrol without the disconnect.
