What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 232425
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 10:14pm
Finished baling first with the 190XT series III pulling a CaseIH 551SB. Temps were high 90s yesterday, topped 100 today. I have the Egging cab, days like today make me think I should see if I can find a replacement fan - it has the housing but no fan or adapter plate
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 7:53pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 8:17pm
Rotobaled some of the cleanest hay hay have ever seen( think it got rained on 5 times).
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 6:07am
Right brake done on the D17. Previous owner obliviously started and quit. End of pins chewed up, different bolts on the covers. Welded bar stock to the pin and pulled it. Have taken out at least a 5 gallon bucket of old carpet/mouse nest between bell housing and brake accesses. I think it was Aladdin's; unfortunately neither Jasmin nor the genie have materialized...
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 6:41am
 Big smileBig smile When I read that I wondered, "No weeds?" Rained on 5 times, probably not the best hay you ever baled.
Badco92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 7:28am
Took and got the head on my '45 C all back together. It had stuck from sitting with the PO and apparently at one point water was getting into the crank case. Since I got the tractor without a head gasket, I can't verify the cause of the problem without putting everything back together... Might fire off today if I can rig some temporary wiring up.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 8:34am
Got another neighbor's WD in the shop looking for more horse power!  He pulled with it last weekend and came in dead last.  Looks like probably going to get an engine rebuild.  I've done 4 WD's over the last winter for neighbors in the area. Farmers are wanting them running again, mostly to put them back to work.
 Seems every farm in this area has a WD or WD45 sitting in the back row, many were new to the farms.  Pattersons was a very strong Allis Chalmers dealer here for years.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 4:26pm
WD did a good job as a log skidder.
Old elm two foot across at the stump.
Marched right up the hill to where I'm splitting them into beams. Expecting that to be a big job with all the cross linking elm does.
WD started right up after sitting since last fall (battery needed a little topping off).
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 8:43pm
The 170 got duty on the driveway with box blade
Put a fully charged battery in the WD45. Discovered a wire from the alternator to the regulator had fallen off. I need to install a GM regulator plug on it. Maybe then it will keep the battery charged. Once up and running it raked some hay with snap coupler rake
190XT hooked to that 3pt spring tooth harrow. It's a 16 footer BTW. Like the one shown in another thread. Had to turn up the sweet corn patch. Two plantings died due to drift or over reach by the chemical applicator. It's conventional but never had that happen before. Will plant again tomorrow
7040 made some round bales later in the afternoon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 7:12pm
Did the ol’ farm fix on the 4660 today. Yesterday bush hogging I blew a power steering line that had been bent at the banjo, so it was well due to go. Replaced the line and was hoping to replace it with a regular o ring boss to JIC because my local parts store didn’t have banjos for the hydraulic lines….Wrong. The banjo bolt is slightly smaller than the fitting. Originally I thought it was metric because the fitting only went in about a half turn before it stopped, but the threads line right up. I ended up running a brass pipe nipple into the steering cylinder, with lots of ptfe tape, and ran the jic right to that.
So, now when it fails (not if) the threads of the cylinder won’t be damaged. Lesson learned? 4660 power steering hoses are unobtainium
Edited by Badco92 - 24 Jun 2025 at 7:14pm
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 4:29pm
Attempting to renovate grass hay land by reseeding small areas barren because of spraying to kill noxious weeds.  Using D-15 II  to cut slots in soil. It utilizes a weighted
7  foot disc with straight (non fluted) blades. I do not have a no till drill!.  I will scatter seed by hand from sitting on the tail gate of a 2 +2 which will be pulling 8 foot roller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 6:57am
One D-17 and 2 WD 45's got a trip to the power washer yesterday. Clean tractors are so much more enjoyable to work on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 5:09am
Put stack weights back on the WFE 45 in preparation for Hutch. Did GPS top speed runs with both 45's, and the 856 too. The WFE is about 1 MPH faster than the NFE. Must be a slight difference in the governor spring.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 6:04am
Tire size/manufacturer, air pressure, lug height?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 7:52am
Tires are the same on both tractors, 16.9x28 Firestone Field and Road. NFE may have a bit more wear but are on 13" rims. WFE are on 15" rims, should be a tad shorter. A quick search shows optical tachs are not to high. I may just purchase one and check WOT RPM's on both tractors, and others.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 3:28am
Not today as it's 9am now, but yesterday evening refitted the flywheel and otherwise reassembled the redneck B, then took it for a celebratory lap around the land to confirm the flywheel actually stayed put this time.
Felt good to be back in business Smile
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 6:55am
Monday I pulled the 1200 field cultivator I donated to the MIAPA up to the grounds with the NFE WD 45. Probably a little over 50 miles round trip. Did not take the most direct route trying to avoid traffic. Did some more GPS runs Sunday. 6080 19.3, 185 w/18.4x30's 18.2, CA-1 surprised me, 12.6, I think. WD Micha with 14.9x28's 12.9. If the video ever finishes uploading.....
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 10:47am
Two days late, but I finished baling 2nd alfalfa Sunday.
I did get a picture of why I really like my 190XT - we filled fuel tanks Friday, Saturday I baled while my brother raked and we both baled Sunday. Two rounds each left to bale, and he had to refuel.
Sorry about the picture quality on the last two, I usually only pack the flip phone on the tractor.
Ted
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 6:18pm
I mowed my ditches with the new to me D17IV and 3pt mower, it was to damm hot to be taking any pictures and had to get her back in the repair shop because of a blown hld line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:12pm
Wow Ted, that green thing really sucks some fuel!! The 190XT’s are rather stingy on fuel for their size, mine always surprises me on how good it is on fuel while baling hay.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:52pm
Why the tillage in the fore-ground? Reseeding? What implement was used?
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 12:27am
Not tillage, alfalfa planted into the openers instead of broadcast. Puts the plants in 6" rows.
And yes, the green ones use more fuel. In alfalfa you can sometimes go two days, but most of the time they get filled every day. In grass they get filled every day (longer days, don't bale grass with dew). My 7000 will usually run 2 days baling before it needs fuel, the 190XT usually gets filled three times a year, and it is the tractor that gets used to mow non-farmed areas. This is the one with the loader engine, so it will be interesting to get my other 190XT hooked up to a baler to see how it compares.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 7:12pm
Spent some time over the last few days playing equipment tetrus to get an old n7 out of the back of the barn. First had to get pretty much everything else out including.
8010 allis
605n vermeer
Mt845b challenger
854 rogator
1386 rogator
4800 massey with leon blade
N5 gleaner with 6r30 corn head
R7 gleaner with pickup head
720 champion
4300 tyler
G minneapolis moline
W900 kw with fertilizer blender
And then the n7
The only equipment left in was the
Twinmaster colombo
630 Pickett
1360 hesston.
Now just putting everything back in except the n7 which will be going for scrap once I pull some parts for a fellow forum member.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 12:53am
Got to take some of the fleet to the local tractor show, the orange took the show this year!!!
Wish I got pictures but was way too busy.
Maybe before they get dirty I’ll get them lined up for a photo shoot…
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:46am
Baled with the 7000 today. I had problems with the oil cooler lines leaking last week, today was first chance to run it since repair. Looks like the leak is fixed. Baled next to last field of 2nd grass, and small field of teff.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 46 minutes ago at 9:31pm
Used the 160, 6060 to make some of our 2nd cutting orchard grass. Beautiful hay and have been blessed with some timely rain all summer long. Hope to make the rest next week, more rain moving in this week.
