What did you do with your Allis Today? |
Page <1 232425 |
TedN ![]() Bronze Level ![]() Joined: 30 Apr 2025 Location: Central WA Points: 55 |
Finished baling first with the 190XT series III pulling a CaseIH 551SB. Temps were high 90s yesterday, topped 100 today. I have the Egging cab, days like today make me think I should see if I can find a replacement fan - it has the housing but no fan or adapter plate
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3870 |
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1384 |
Rotobaled some of the cleanest hay hay have ever seen( think it got rained on 5 times).
Steve A ![]() Silver Level ![]() ![]() Joined: 12 Apr 2012 Location: NLP Mi Points: 241 |
Right brake done on the D17. Previous owner obliviously started and quit. End of pins chewed up, different bolts on the covers. Welded bar stock to the pin and pulled it. Have taken out at least a 5 gallon bucket of old carpet/mouse nest between bell housing and brake accesses. I think it was Aladdin's; unfortunately neither Jasmin nor the genie have materialized...
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4032 |
Badco92 ![]() Bronze Level ![]() Joined: 27 May 2025 Location: Maine Points: 3 |
Took and got the head on my '45 C all back together. It had stuck from sitting with the PO and apparently at one point water was getting into the crank case. Since I got the tractor without a head gasket, I can't verify the cause of the problem without putting everything back together... Might fire off today if I can rig some temporary wiring up.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3906 |
Got another neighbor's WD in the shop looking for more horse power! He pulled with it last weekend and came in dead last. Looks like probably going to get an engine rebuild. I've done 4 WD's over the last winter for neighbors in the area. Farmers are wanting them running again, mostly to put them back to work. Seems every farm in this area has a WD or WD45 sitting in the back row, many were new to the farms. Pattersons was a very strong Allis Chalmers dealer here for years.
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 440 |
WD did a good job as a log skidder. Old elm two foot across at the stump. Marched right up the hill to where I'm splitting them into beams. Expecting that to be a big job with all the cross linking elm does. WD started right up after sitting since last fall (battery needed a little topping off). . |
The 170 got duty on the driveway with box blade
Put a fully charged battery in the WD45. Discovered a wire from the alternator to the regulator had fallen off. I need to install a GM regulator plug on it. Maybe then it will keep the battery charged. Once up and running it raked some hay with snap coupler rake 190XT hooked to that 3pt spring tooth harrow. It's a 16 footer BTW. Like the one shown in another thread. Had to turn up the sweet corn patch. Two plantings died due to drift or over reach by the chemical applicator. It's conventional but never had that happen before. Will plant again tomorrow 7040 made some round bales later in the afternoon ![]() |
Did the ol’ farm fix on the 4660 today. Yesterday bush hogging I blew a power steering line that had been bent at the banjo, so it was well due to go. Replaced the line and was hoping to replace it with a regular o ring boss to JIC because my local parts store didn’t have banjos for the hydraulic lines….Wrong. The banjo bolt is slightly smaller than the fitting. Originally I thought it was metric because the fitting only went in about a half turn before it stopped, but the threads line right up. I ended up running a brass pipe nipple into the steering cylinder, with lots of ptfe tape, and ran the jic right to that.
So, now when it fails (not if) the threads of the cylinder won’t be damaged. Lesson learned? 4660 power steering hoses are unobtainium Edited by Badco92 - 24 Jun 2025 at 7:14pm |
Marlyn nwia ![]() Silver Level Access ![]() Joined: 11 Sep 2009 Points: 392 |
Attempting to renovate grass hay land by reseeding small areas barren because of spraying to kill noxious weeds. Using D-15 II to cut slots in soil. It utilizes a weighted
7 foot disc with straight (non fluted) blades. I do not have a no till drill!. I will scatter seed by hand from sitting on the tail gate of a 2 +2 which will be pulling 8 foot roller.
One D-17 and 2 WD 45's got a trip to the power washer yesterday. Clean tractors are so much more enjoyable to work on!
Put stack weights back on the WFE 45 in preparation for Hutch. Did GPS top speed runs with both 45's, and the 856 too. The WFE is about 1 MPH faster than the NFE. Must be a slight difference in the governor spring.
only AC orange ![]() Orange Level Access ![]() Joined: 06 Dec 2014 Location: Eastern Indiana Points: 511 |
Tire size/manufacturer, air pressure, lug height?
Tires are the same on both tractors, 16.9x28 Firestone Field and Road. NFE may have a bit more wear but are on 13" rims. WFE are on 15" rims, should be a tad shorter. A quick search shows optical tachs are not to high. I may just purchase one and check WOT RPM's on both tractors, and others.
ekjdm14 ![]() Orange Level Access ![]() Joined: 20 Aug 2024 Location: Alsager UK Points: 970 |
Not today as it's 9am now, but yesterday evening refitted the flywheel and otherwise reassembled the redneck B, then took it for a celebratory lap around the land to confirm the flywheel actually stayed put this time.
Felt good to be back in business
Stuck Farmer
Monday I pulled the 1200 field cultivator I donated to the MIAPA up to the grounds with the NFE WD 45. Probably a little over 50 miles round trip. Did not take the most direct route trying to avoid traffic. Did some more GPS runs Sunday. 6080 19.3, 185 w/18.4x30's 18.2, CA-1 surprised me, 12.6, I think. WD Micha with 14.9x28's 12.9. If the video ever finishes uploading.....
Two days late, but I finished baling 2nd alfalfa Sunday.
![]() I did get a picture of why I really like my 190XT - we filled fuel tanks Friday, Saturday I baled while my brother raked and we both baled Sunday. Two rounds each left to bale, and he had to refuel. ![]() ![]() Sorry about the picture quality on the last two, I usually only pack the flip phone on the tractor. Ted |
Kenny L. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: NEIOWA Points: 1347 |
I mowed my ditches with the new to me D17IV and 3pt mower, it was to damm hot to be taking any pictures and had to get her back in the repair shop because of a blown hld line.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5187 |
Wow Ted, that green thing really sucks some fuel!! The 190XT’s are rather stingy on fuel for their size, mine always surprises me on how good it is on fuel while baling hay.
Why the tillage in the fore-ground? Reseeding? What implement was used?
Not tillage, alfalfa planted into the openers instead of broadcast. Puts the plants in 6" rows.
And yes, the green ones use more fuel. In alfalfa you can sometimes go two days, but most of the time they get filled every day. In grass they get filled every day (longer days, don't bale grass with dew). My 7000 will usually run 2 days baling before it needs fuel, the 190XT usually gets filled three times a year, and it is the tractor that gets used to mow non-farmed areas. This is the one with the loader engine, so it will be interesting to get my other 190XT hooked up to a baler to see how it compares. |
Acguywill ![]() Bronze Level ![]() Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 139 |
Spent some time over the last few days playing equipment tetrus to get an old n7 out of the back of the barn. First had to get pretty much everything else out including.
8010 allis 605n vermeer Mt845b challenger 854 rogator 1386 rogator 4800 massey with leon blade N5 gleaner with 6r30 corn head R7 gleaner with pickup head 720 champion 4300 tyler G minneapolis moline W900 kw with fertilizer blender And then the n7 The only equipment left in was the Twinmaster colombo 630 Pickett 1360 hesston. Now just putting everything back in except the n7 which will be going for scrap once I pull some parts for a fellow forum member. |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 905 |
Got to take some of the fleet to the local tractor show, the orange took the show this year!!!
Wish I got pictures but was way too busy. Maybe before they get dirty I’ll get them lined up for a photo shoot… ![]() ![]() |
Page <1 232425 |
