What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 232425
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 10:14pm
Finished baling first with the 190XT series III pulling a CaseIH 551SB. Temps were high 90s yesterday, topped 100 today. I have the Egging cab, days like today make me think I should see if I can find a replacement fan - it has the housing but no fan or adapter plate
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 7:53pm
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2025 at 8:17pm
Rotobaled some of the cleanest hay hay have ever seen( think it got rained on 5 times).
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 6:07am
Right brake done on the D17. Previous owner obliviously started and quit. End of pins chewed up, different bolts on the covers. Welded bar stock to the pin and pulled it. Have taken out at least a 5 gallon bucket of old carpet/mouse nest between bell housing and brake accesses. I think it was Aladdin's; unfortunately neither Jasmin nor the genie have materialized...
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 6:41am
 Big smileBig smile When I read that I wondered, "No weeds?" Rained on 5 times, probably not the best hay you ever baled.
Badco92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 7:28am
Took and got the head on my '45 C all back together. It had stuck from sitting with the PO and apparently at one point water was getting into the crank case. Since I got the tractor without a head gasket, I can't verify the cause of the problem without putting everything back together... Might fire off today if I can rig some temporary wiring up.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 8:34am
Got another neighbor's WD in the shop looking for more horse power!  He pulled with it last weekend and came in dead last.  Looks like probably going to get an engine rebuild.  I've done 4 WD's over the last winter for neighbors in the area. Farmers are wanting them running again, mostly to put them back to work.
 Seems every farm in this area has a WD or WD45 sitting in the back row, many were new to the farms.  Pattersons was a very strong Allis Chalmers dealer here for years.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 4:26pm
WD did a good job as a log skidder.
Old elm two foot across at the stump.
Marched right up the hill to where I'm splitting them into beams. Expecting that to be a big job with all the cross linking elm does.
WD started right up after sitting since last fall (battery needed a little topping off).
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 8:43pm
The 170 got duty on the driveway with box blade
Put a fully charged battery in the WD45. Discovered a wire from the alternator to the regulator had fallen off. I need to install a GM regulator plug on it. Maybe then it will keep the battery charged. Once up and running it raked some hay with snap coupler rake
190XT hooked to that 3pt spring tooth harrow. It's a 16 footer BTW. Like the one shown in another thread. Had to turn up the sweet corn patch. Two plantings died due to drift or over reach by the chemical applicator. It's conventional but never had that happen before. Will plant again tomorrow
7040 made some round bales later in the afternoon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badco92 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2025 at 7:12pm
Did the ol’ farm fix on the 4660 today. Yesterday bush hogging I blew a power steering line that had been bent at the banjo, so it was well due to go. Replaced the line and was hoping to replace it with a regular o ring boss to JIC because my local parts store didn’t have banjos for the hydraulic lines….Wrong. The banjo bolt is slightly smaller than the fitting. Originally I thought it was metric because the fitting only went in about a half turn before it stopped, but the threads line right up. I ended up running a brass pipe nipple into the steering cylinder, with lots of ptfe tape, and ran the jic right to that.
So, now when it fails (not if) the threads of the cylinder won’t be damaged. Lesson learned? 4660 power steering hoses are unobtainium
Edited by Badco92 - 24 Jun 2025 at 7:14pm
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 4:29pm
Attempting to renovate grass hay land by reseeding small areas barren because of spraying to kill noxious weeds.  Using D-15 II  to cut slots in soil. It utilizes a weighted
7  foot disc with straight (non fluted) blades. I do not have a no till drill!.  I will scatter seed by hand from sitting on the tail gate of a 2 +2 which will be pulling 8 foot roller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 6:57am
One D-17 and 2 WD 45's got a trip to the power washer yesterday. Clean tractors are so much more enjoyable to work on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 5:09am
Put stack weights back on the WFE 45 in preparation for Hutch. Did GPS top speed runs with both 45's, and the 856 too. The WFE is about 1 MPH faster than the NFE. Must be a slight difference in the governor spring.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 6:04am
Tire size/manufacturer, air pressure, lug height?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 7:52am
Tires are the same on both tractors, 16.9x28 Firestone Field and Road. NFE may have a bit more wear but are on 13" rims. WFE are on 15" rims, should be a tad shorter. A quick search shows optical tachs are not to high. I may just purchase one and check WOT RPM's on both tractors, and others.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 3:28am
Not today as it's 9am now, but yesterday evening refitted the flywheel and otherwise reassembled the redneck B, then took it for a celebratory lap around the land to confirm the flywheel actually stayed put this time.
Felt good to be back in business Smile
Stuck Farmer
This page was generated in 0.510 seconds.
