What did you do with your Allis Today? |
Page <1 21222324> |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3888 |
Not my tractor but I picked a load of ear corn with a WD and mounted picker yesterday at a friends place. Always a good time over at Dan's. Today, going to get my WD out and clean the seed out of the drill. Left it in there thinking I'd seed around the new buildings this fall..... Well, it's so dry weeds won't even grow!
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8396 |
Got the PS 8070 catching the R62
powertech84 ![]() Silver Level ![]() Joined: 17 Oct 2009 Location: Wisconsin Points: 467 |
I got the 7580 back in the field. I bought this tractor last spring. It wasn't running at the time, and was advertised as a parts tractor. The front PTO shaft bearing had gone out and exploded the driveshaft. I did a lot of work over the summer, and just barely got it back in the field. Hopefully going to get a few more things done before next year, like sandblast and paint the rims, install some fenders and get some wiring fixed. Maybe add three point if it works out.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3679 |
That’s quite the project there. Keep up the good work
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1277 |
I wish i had the brains and knowledge to do a project like that......but i can do a root canal. Still rather fix a modern tractor. They are quieter
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 952 |
Our 185 T is running a belt conveyor unloading soys from hopper B trains
at the moment by operating the hyd motor than runs the drive over conveyor.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
![]() 170 is running a new to us Westfield. 200 on one wagon. 7040 is staged with another |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 827 |
Got to go out and disk with the D21 for the first time (for the tractor) boy was that a blast!!!
powertech84 thanks for saving another Allis!!! Looks like a good project!!! |
Yesterday, drove one of my Red girls, (856), to a local plow day. My buddy Dan pulled the WFE 45 up on the trailer. I plowed with the 8 for awhile and Dan the 45. After lunch I showed him how to run the 856 and semi-mount Oliver plow. He picked it up pretty quickly and I took a few rounds on the 45. Good news on this front, my coulter work seems to have helped and the 73 did as good a job as any of the small rigs. Ground was insanely hard! Some of the bigger semi-mounts were even floating up out of the ground at times.
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
Sold a little Allis 912 garden tractor so I moved around some stuff in the "keep" pile. This loader sure has been handy. ![]() |
German Shepherd dad
In the garden yesterday, ran the No. 4 sub-soiler with the NFE 45. Plowed the first furrow with the WFE 45. Then the experimentation began. Plowed a few passes with the D-15 and 62 plow. It's really a 63 that has been cut down. At any rate, it didn't work too bad. Then the curiosity bug bit me, put the 52 on to see if it would go in the ground. Well, not the best. Did eventually get it to plow, just not well. Ground was like concrete, looks nasty today. Decided to just finish with the 45. So I used two tractors and three plows to do about 1/4 acre. 6080 was on loader duty as always.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2323 |
sold another one today!!!! YAY!!!
Cleaned up and repainted the brackets for the heat houser since that will be going back on soon. The jam bolt holes on the lower brackets were worn out so I drilled to the next size, tapped the threads and gave them new hardware. Got as close to the original green as I could.
German Shepherd dad
Got D-17-2 running, (barely) and moved it to a different building. I think the real problem is rust in the sediment bowl neck. I'll chase that another day.
Harrowed the driveway with CA-2. That seems to be it's main job and it's perfect for it. Got the 720 running and brought it to the house in preparation for winter. Not sure exactly where it will sleep this winter just yet. Trying to get things organized before that frozen stuff flies.
Spemt the afternoon straightening the trees I put in the last 4 days.
German Shepherd dad
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8402 |
Derricks ![]() Bronze Level ![]() Joined: 10 Aug 2024 Location: Wisconsin Points: 30 |
I rescued this WD from being sent for scrap.
New lawn ornament for our farm. ![]() |
StanGreen ![]() Bronze Level ![]() Joined: 13 Nov 2022 Location: US Points: 50 |
I got my 3 bottom plow all ready for a plow day next spring. Now she get to take a long winter nap.
I ordered 2 new front tires for the ol “57 Wd45, now it’s going to have all 4 new tires!!!
That's always a good feeling! I am a proponent of good tires on tractors, or anything else for that matter.
Did a little stalk chopping with the 185, with a D-17 gas tank strapped to the wheel. Shot some video, will post a link when I get it uploaded. Just need to get the media and diesel fuel out and wash it up. Should be ready to go back on after that.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3870 |
Fired up the "hot rod" WD and plowed the place out after "somebody" dumped 8 inches of white stuff on me!!
I outbid a scrapper for this a while back
![]() First thing I've done with it. It's the only thing I have that would lift this lathe. |
Finished installing upper and lower endless belts onthe roto baler. Just about as annoying job as mack said it would be. If i get a couple of dry days, going to try to bale some leaves with it
Put the gas tank back on D-17-2 yesterday and fired her up! Sounds really good with a constant fuel supply. Side note; If I never remove-replace another D-series tank, I'll be okay with that. What a pita!
Changed the valve cores on the 6080! Left rear tire looked just a bit squatty, hmm, not good sauceman! I try to change them every 3 years, at least, in fluid filled tires. 1 tire at 6.5 psi, other at about 7.5, set them at 15 after the change. Don't think I put any air in them since the last change, hopefully good to go for 2-3 more years.
Working on another YouTube video, should mention this I suppose. It is good preventative maintenance. Probably ought to do CA-2 when it warms up as it's been here about 3 years already. Also going to need to pick up some more new cores at the store!
Where do you get yours? Used to find them at Theisens and Fleet Farm. No more.
Pretty sure the last batch came from Theisen's. If they don't have any I guess I'll check with Hewitt in Monroe.
So, may have over-reacted to your post. Bought 10 four packs at Marshalltown Theisen's yesterday. Should last awhile? If you're still in need of some when June gets here, I'll bring you some to Amana.
Page <1 21222324> |
