What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 21222324>
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 6:31am
Not my tractor but I picked a load of ear corn with a WD and mounted picker yesterday at a friends place. Always a good time over at Dan's.
Today, going to get my WD out and clean the seed out of the drill. Left it in there thinking I'd seed around the new buildings this fall..... Well, it's so dry weeds won't even grow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 5:18pm
Got the PS 8070 catching the R62
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 7:26am
I got the 7580 back in the field. I bought this tractor last spring. It wasn't running at the time, and was advertised as a parts tractor. The front PTO shaft bearing had gone out and exploded the driveshaft. I did a lot of work over the summer, and just barely got it back in the field. Hopefully going to get a few more things done before next year, like sandblast and paint the rims, install some fenders and get some wiring fixed. Maybe add three point if it works out.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 11:47am
That’s quite the project there. Keep up the good work
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 6:53pm
I wish i had the brains and knowledge to do a project like that......but i can do a root canal. Still rather fix a modern tractor. They are quieter
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 8:52pm
Our 185 T is running a belt conveyor unloading soys from hopper B trains
at the moment by operating the hyd motor than runs the drive over conveyor.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 8:33pm
170 is running a new to us Westfield. 200 on one wagon. 7040 is staged with another
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 9:39pm
Got to go out and disk with the D21 for the first time (for the tractor) boy was that a blast!!!
powertech84 thanks for saving another Allis!!! Looks like a good project!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 6:39am
Yesterday, drove one of my Red girls, (856), to a local plow day. My buddy Dan pulled the WFE 45 up on the trailer. I plowed with the 8 for awhile and Dan the 45. After lunch I showed him how to run the 856 and semi-mount Oliver plow. He picked it up pretty quickly and I took a few rounds on the 45. Good news on this front, my coulter work seems to have helped and the 73 did as good a job as any of the small rigs. Ground was insanely hard! Some of the bigger semi-mounts were even floating up out of the ground at times.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 6:26pm
Sold a little Allis 912 garden tractor so I moved around some stuff in the "keep" pile. This loader sure has been handy.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 8:51am
In the garden yesterday, ran the No. 4 sub-soiler with the NFE 45. Plowed the first furrow with the WFE 45. Then the experimentation began. Plowed a few passes with the D-15 and 62 plow. It's really a 63 that has been cut down. At any rate, it didn't work too bad. Then the curiosity bug bit me, put the 52 on to see if it would go in the ground. Well, not the best. Did eventually get it to plow, just not well. Ground was like concrete, looks nasty today. Decided to just finish with the 45. So I used two tractors and three plows to do about 1/4 acre. 6080 was on loader duty as always.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 9:27am
sold another one today!!!! YAY!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 6:37am
Cleaned up and repainted the brackets for the heat houser since that will be going back on soon. The jam bolt holes on the lower brackets were worn out so I drilled to the next size, tapped the threads and gave them new hardware. Got as close to the original green as I could.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 9:22am
Got D-17-2 running, (barely) and moved it to a different building. I think the real problem is rust in the sediment bowl neck. I'll chase that another day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 8:29am
Harrowed the driveway with CA-2. That seems to be it's main job and it's perfect for it. Got the 720 running and brought it to the house in preparation for winter. Not sure exactly where it will sleep this winter just yet. Trying to get things organized before that frozen stuff flies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 4:21pm
Spemt the afternoon straightening the trees I put in the last 4 days.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 12:43am
CA clean up.
 Chris and Cheryl
Derricks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2024 at 6:44pm
I rescued this WD from being sent for scrap.
New lawn ornament for our farm.
StanGreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 11:02am
I got my 3 bottom plow all ready for a plow day next spring. Now she get to take a long winter nap. Plow on a WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 1:28pm
I ordered 2 new front tires for the ol “57 Wd45, now it’s going to have all 4 new tires!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2024 at 8:12am
That's always a good feeling! I am a proponent of good tires on tractors, or anything else for that matter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2024 at 5:36am
Did a little stalk chopping with the 185, with a D-17 gas tank strapped to the wheel. Shot some video, will post a link when I get it uploaded. Just need to get the media and diesel fuel out and wash it up. Should be ready to go back on after that.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2024 at 5:47pm
Fired up the "hot rod" WD and plowed the place out after "somebody" dumped 8 inches of  white stuff on me!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 5:52pm
I outbid a scrapper for this a while back
First thing I've done with it. It's the only thing I have that would lift this lathe.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 6:33pm
Finished installing upper and lower endless belts onthe roto baler. Just about as annoying job as mack said it would be. If i get a couple of dry days, going to try to bale some leaves with it
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 5:02am
Put the gas tank back on D-17-2 yesterday and fired her up! Sounds really good with a constant fuel supply. Side note; If I never remove-replace another D-series tank, I'll be okay with that. What a pita!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 5:43am
Changed the valve cores on the 6080! Left rear tire looked just a bit squatty, hmm, not good sauceman! I try to change them every 3 years, at least, in fluid filled tires. 1 tire at 6.5 psi, other at about 7.5, set them at 15 after the change. Don't think I put any air in them since the last change, hopefully good to go for 2-3 more years.
Working on another YouTube video, should mention this I suppose. It is good preventative maintenance. Probably ought to do CA-2 when it warms up as it's been here about 3 years already. Also going to need to pick up some more new cores at the store!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 7:54am
Where do you get yours? Used to find them at Theisens and Fleet Farm. No more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 6:14am
Pretty sure the last batch came from Theisen's. If they don't have any I guess I'll check with Hewitt in Monroe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 9:17am
So, may have over-reacted to your post. Bought 10 four packs at Marshalltown Theisen's yesterday. Should last awhile? If you're still in need of some when June gets here, I'll bring you some to Amana.
This page was generated in 0.126 seconds.
