What did you do with your Allis Today? |
Post Reply | Page <1 202122 |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3639 |
Changed the oil in the 6080. Have a new air filter to go in one of these days, loader has to come off to do that so I keep putting it off. It's not like this thing is out working in dusty conditions but I would like to get it done this year.
Chad S
Bronze Level Joined: 13 Sep 2009 Location: CENTERAL IOWA Points: 86 |
Mowed around some fields with the 170XT
36 WC,41 WC,53 WD45,57 D14,65 D21,68 XT,72 XT,81 7045
JSHIVERS
Bronze Level Joined: 24 Jun 2021 Location: Bloomington,IN Points: 59 |
Cut the old steering wheel off of my B, with the "wheel of death" and installed a new/used one picked up at a tractor show earlier this summer. Then went for a test drive to be sure it wouldn't come off in my hands! Success!
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3362 |
Mowed some areas with the 170 and Woods 3pt brush cutter. Moved some round bales in for storage with the 7045 and the 200 got to grade a bit of the driveway with a 3pt blade.
Acguywill
Bronze Level Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 75 |
Used the fr30 to move an old grain bin out of the way for a barn that we are moving from my old place to the calving corrals. Put the dividers on the front of the 8010 and started mowing the male bays out of the seed canola field.
StanGreen
Bronze Level Joined: 13 Nov 2022 Location: US Points: 38 |
It all started out simple enough; remove a broken front lug bolt. After every trick in my book, I failed to remove it. I ended up taking it to a machine shop to remove the bolt. In the process, I took the hub apart. The front bearing looked like it was greased sometime in the last 10 years, but the rear looked like it had the original 70 year old grease! Today's task is to clean and grease the bearings. Then put it all back together. Then since I did one side, I might as well do the other side! I am learning that in antique tractors, there are no simple projects!
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4834 |
Since we haven't had much rain in the last 2 months, not much going on our farm besides feeding our cattle. No 2nd cut hay making, my XT has sit idle since the beginning of June as most of the tractors. Hooked the 160 to our Woods brush mower and mowed thistles in our pasture fields along with my older brother Jim running the D15 II and NH sickle mower. Fun to be back on a tractor but sure wish we was making hay.
Chugach
Bronze Level Joined: 30 Nov 2023 Location: Alaska Points: 36 |
Struggling with putting camshaft thrust cover back on with all the parts on my D 15 Series II
dkattau
Silver Level Joined: 20 Mar 2011 Location: Nebraska Points: 264 |
Hauled a WD/WD-45 hybrid home to put the Allis bale loader on.
plummerscarin
Used the 7045 to flatten several rolls of woven wire to haul off for scrap
JSHIVERS
Had a flat front tire on the 1940 B. Removed the front steer and had it patched. Turns out I had a couple of sharp thorns stuck in it. Good to have it all back together again.
AC720Man
Started my XT for the first time since early June. No hay to mow or bale so I used it to pull a large tree limb to the burn pile. Hooked up my 4 bottom series 70 plow so I can replace the shares. If we don’t get a good rain soon it all will be sitting idle again. Used the D15 to sickle mow some weeds, practically the only thing growing.
only AC orange
Silver Level Access Joined: 06 Dec 2014 Location: Eastern Indiana Points: 450 |
Put the "70" series 3X14 plow on Series IV D-17 and plowed garden. Might have a plow day coming up and wanted to know it was ready to go!
StanGreen
Finished a repair on the WD45, which has been needed for over 50 years. You see, Grandpa dropped a tree on the tractor 50 years ago. It mangles the gas tank which Grandpa hack a patch together for it. I did not realize how bad it was until I took the old tank off! Yes, I think it held gas but I would not have called it safe. So I restored a used tank and it is now on the tractor! On to the next restoration task.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22201 |
Ahh, mowing the back field is always a pleasure. It had been a while since I’d done a full pass, so it was satisfying to see the tall grass finally cut down. After that, I hooked up the trailer to haul some firewood from the woodshed to the house. The old tractor ran like a champ, as always
IBWD MIke
Got the NFE 45 out and hooked on the 7' disc, worked up a little piece I had worked over when the dozer was here. Was an old cow-path. Guy that bales the grass hay didn't like it, better now. Then got WD 'Micha' out and drilled some grass seed and oats. If we get rain now, that will be a positive.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2313 |
tried to sell a couple more of them!
plummerscarin
Reckon you can figure out what I did
To be honest, my accountant did the raking while I played golf . She refused to use the WD45 and snap coupler rake but this was an open field for easy work Edited by plummerscarin - 25 Aug 2024 at 8:31pm |
CA13414
Silver Level Joined: 25 Feb 2024 Location: Nebraska Points: 256 |
That is awesome. Team approach!!
Rake it, roll it and move/stack it!! It only takes three. Hope the golf was awesome!! |
IBWD MIke
Plummer, hope the air works in that bailing tractor! Would have been a pretty miserable job if not. It's great the better half is willing to rake. I took the WF 45 to the power washer to get the mud off the tires from plowing a M-town. Then remembered there might be a plow day this coming weekend. Oh well, at least it's clean for a bit.
plummerscarin
Golf was good. Only play once a year with brother and 2 cousins. Damn hot tho. I did a 134 conversion on that 7040 but for some reason have lost power to the compressor. Another fixit project!
IBWD MIke
Dusted off the D-15 and took it on a tractor ride yesterday! First time it's been out of the shed this year. No flat tires this year! Need to change the oil in it, might do that this morning. Going on another ride this afternoon but taking a Red one on it. It needs a little love too so maybe we change oil in the 15 while changing the fuel filters on the 856. That 8 is getting a pair of new batteries today too!
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3714 |
Hooked the '47 WC to the post pounder and knocked in some new posts to extend some fence. Too hot to work out there the last couple of days so I'll run the wire next week when it cools down a little.
plummerscarin
Hooked on to the 303 with the 170 and baled some grass hay. The thrower smoked a belt so I was the thrower today. The grandkids helped out stacking. It is their first venture in to hay making
My old self propelled mower conditioner was not working well so the grass was cut with the 170 and Woods rotary. That was 2 weeks ago. There was a delay in baling cuz I spent a week in Ontario bowhunting bears |
Dirt Farmer
Silver Level Access Joined: 15 Sep 2020 Location: Illinois Points: 336 |
Don't leave us hanging did you get a bear, didnt happen if there's no pictures. At least we know you made it back unharmed since you posted. Good picture of the helpers all smiling too, hope they enjoyed it, they will look back at today with fond memories in years to come and bet next time they wear jeans.
plummerscarin
Yeah, I warned them about shorts but they insisted they were fine. They did concede I was right
This is a shooter but he immediately layed down over the bait leaving me no shot. The blind was 30yds to the left. This is a sow that brought 3 cubs to the bait site. We don't shoot bears with cubs. Blind was set up on the ground 30yds out at both bait stations Edited by plummerscarin - 14 Sep 2024 at 11:03pm |
IBWD MIke
Tripped over mine mostly yesterday. That time of year, getting things ready for harvest. Was going to pull some wagons around with the NF 45 but got bogged down working on the grain truck. Maybe today will be the day? Did take the D-15 for a short ride. Checked some corn, one field is about 20%. If it stays dry, might combine some next weekend.
nanuk
Silver Level Joined: 22 Aug 2013 Location: Saskatchewan Points: 225 |
Nothing today, still too wet.
But I'm up to over 1100. 335 6' hay bales 815 6' straw bales Still may have to roll up straw on another 130 acres of barley. Won't know for a few days. all this was done with my 7060. If I could widen my tread, it would be the PERFECT baling tractor for me.
AC7060Pd 1975
