What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 20212223>
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 8:34am
Changed the oil in the 6080. Have a new air filter to go in one of these days, loader has to come off to do that so I keep putting it off. It's not like this thing is out working in dusty conditions but I would like to get it done this year.
Chad S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad S Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2024 at 4:58pm
Mowed around some fields with the 170XT
36 WC,41 WC,53 WD45,57 D14,65 D21,68 XT,72 XT,81 7045
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 8:31am
Cut the old steering wheel off of my B, with the "wheel of death" and installed a new/used one picked up at a tractor show earlier this summer.  Then went for a test drive to be sure it wouldn't come off in my hands!  Success!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 2:00pm
Mowed some areas with the 170 and Woods 3pt brush cutter. Moved some round bales in for storage with the 7045 and the 200 got to grade a bit of the driveway with a 3pt blade.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 11:36pm
Used the fr30 to move an old grain bin out of the way for a barn that we are moving from my old place to the calving corrals. Put the dividers on the front of the 8010 and started mowing the male bays out of the seed canola field.
StanGreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2024 at 8:58pm
It all started out simple enough; remove a broken front lug bolt. After every trick in my book, I failed to remove it. I ended up taking it to a machine shop to remove the bolt. In the process, I took the hub apart. The front bearing looked like it was greased sometime in the last 10 years, but the rear looked like it had the original 70 year old grease! Today's task is to clean and grease the bearings. Then put it all back together. Then since I did one side, I might as well do the other side! I am learning that in antique tractors, there are no simple projects!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2024 at 8:19pm
Since we haven't had much rain in the last 2 months, not much going on our farm besides feeding our cattle. No 2nd cut hay making, my XT has sit idle since the beginning of June as most of the tractors. Hooked the 160 to our Woods brush mower and mowed thistles in our pasture fields along with my older brother Jim running the D15 II and NH sickle mower. Fun to be back on a tractor but sure wish we was making hay.
Chugach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chugach Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 5:52pm
Struggling with putting camshaft thrust cover back on with all the parts on my D 15 Series II
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 6:19pm
Hauled a WD/WD-45 hybrid home to put the Allis bale loader on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 7:11pm
Used the 7045 to flatten several rolls of woven wire to haul off for scrap
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2024 at 8:50pm
Had a flat front tire on the 1940 B.  Removed the front steer and had it patched.  Turns out I had a couple of sharp thorns stuck in it.  Good to have it all back together again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2024 at 10:02pm
Started my XT for the first time since early June. No hay to mow or bale so I used it to pull a large tree limb to the burn pile. Hooked up my 4 bottom series 70 plow so I can replace the shares. If we don’t get a good rain soon it all will be sitting idle again. Used the D15 to sickle mow some weeds, practically the only thing growing.
only AC orange View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2024 at 8:12am
Put the "70" series 3X14 plow on Series IV D-17 and plowed garden. Might have a plow day coming up and wanted to know it was ready to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2024 at 8:26am
Finished a repair on the WD45, which has been needed for over 50 yearsConfused. You see, Grandpa dropped a tree on the tractor 50 years ago. It mangles the gas tank which Grandpa hack a patch together for it. I did not realize how bad it was until I took the old tank off! Yes, I think it held gas but I would not have called it safe. So I restored a used tank and it is now on the tractor! On to the next restoration task.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2024 at 8:28am
Ahh, mowing the back field is always a pleasure. It had been a while since I’d done a full pass, so it was satisfying to see the tall grass finally cut down. After that, I hooked up the trailer to haul some firewood from the woodshed to the house. The old tractor ran like a champ, as always
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 7:51am
Got the NFE 45 out and hooked on the 7' disc, worked up a little piece I had worked over when the dozer was here. Was an old cow-path. Guy that bales the grass hay didn't like it, better now. Then got WD 'Micha' out and drilled some grass seed and oats. If we get rain now, that will be a positive.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 10:34am
tried to sell a couple more of them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:27pm
Reckon you can figure out what I did
To be honest, my accountant did the raking while I played golf . She refused to use the WD45 and snap coupler rake but this was an open field for easy work
Edited by plummerscarin - 25 Aug 2024 at 8:31pm
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:01pm
That is awesome. Team approach!!
Rake it, roll it and move/stack it!! It only takes three. Hope the golf was awesome!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 6:21am
Plummer, hope the air works in that bailing tractor! Would have been a pretty miserable job if not. It's great the better half is willing to rake.
I took the WF 45 to the power washer to get the mud off the tires from plowing a M-town. Then remembered there might be a plow day this coming weekend. Oh well, at least it's clean for a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 7:16am
Golf was good. Only play once a year with brother and 2 cousins. Damn hot tho. I did a 134 conversion on that 7040 but for some reason have lost power to the compressor. Another fixit project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2024 at 6:15am
Dusted off the D-15 and took it on a tractor ride yesterday! First time it's been out of the shed this year. No flat tires this year! Need to change the oil in it, might do that this morning. Going on another ride this afternoon but taking a Red one on it. It needs a little love too so maybe we change oil in the 15 while changing the fuel filters on the 856. That 8 is getting a pair of new batteries today too!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2024 at 9:16am
Hooked the '47 WC to the post pounder and knocked in some new posts to extend some fence.  Too hot to work out there the last couple of days so I'll run the wire next week when it cools down a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 9:23pm
Hooked on to the 303 with the 170 and baled some grass hay. The thrower smoked a belt so I was the thrower today. The grandkids helped out stacking. It is their first venture in to hay making
My old self propelled mower conditioner was not working well so the grass was cut with the 170 and Woods rotary. That was 2 weeks ago. There was a delay in baling cuz I spent a week in Ontario bowhunting bears
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 10:04pm
Don't leave us hanging did you get a bear, didnt happen if there's no pictures. At least we know you made it back unharmed since you posted. Good picture of the helpers all smiling too, hope they enjoyed it, they will look back at today with fond memories in years to come and bet next time they wear jeans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 11:01pm
Yeah, I warned them about shorts but they insisted they were fine. They did concede I was right
This is a shooter but he immediately layed down over the bait leaving me no shot. The blind was 30yds to the left.
This is a sow that brought 3 cubs to the bait site. We don't shoot bears with cubs.
Blind was set up on the ground 30yds out at both bait stations
Edited by plummerscarin - 14 Sep 2024 at 11:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 6:12am
Tripped over mine mostly yesterday. That time of year, getting things ready for harvest. Was going to pull some wagons around with the NF 45 but got bogged down working on the grain truck. Maybe today will be the day? Did take the D-15 for a short ride.
Checked some corn, one field is about 20%. If it stays dry, might combine some next weekend.
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 8:57am
Nothing today, still too wet.
But I'm up to over 1100.
335 6' hay bales
815 6' straw bales
Still may have to roll up straw on another 130 acres of barley.  Won't know for a few days.
all this was done with my 7060.
If I could widen my tread, it would be the PERFECT baling tractor for me.
AC7060Pd 1975
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2024 at 6:11pm
Neighbor thought he was going to be 50 bales short for his sheep so rotobaled a couple of acres for him. Why does the baler always work the best the last time you use it? Made 80 bales in little over an hour. Corn still too wet to pick so try and get caught up on the day job
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 6:09am
Just a little brush hogging at my buddys place this weekend. He wants to do a pumpkin patch here in the spring.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
This page was generated in 0.093 seconds.
