What combine engine will fit in a 185 diesel
autobody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Topic: What combine engine will fit in a 185 diesel
    Posted: 15 Jun 2017 at 8:16am
I have a 185 diesel that is getting water in oil. Thought it might be easier to swap out engine than overhauling mine. Need to know which combine engine to get
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 8:42am
likely sleeve orings.  if you overhaul it you would have a new engine.  combine engine swaps are not straight forward drop ins and you never really know what your getting.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 10:21am
I agree with CAL! Just rebuild your engine!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 9:18pm
I agree as well.  Rebuild your engine.  You will know what you have.  No telling what you will get in a used engine.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 9:52pm
it has been discussed at length here before - it is a lot of work - combines have no provision for hyd pump drive - different oil pump unless you find a G diesel and still have to change front covers - water pump will not fit radiator - it will work - we have done it several times - but it is cheaper and ez ier to overhaul your engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 10:27pm
If the lower bores are bad enough,there are shops that bore and sleeve them.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 7:08am
To answer your question, any 301 will work. It all depends on how much stuff you want to change.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 3:08pm
Thanks for input will do an overhaul
This page was generated in 0.199 seconds.
