WF battery charging
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: WF battery charging
    Posted: 23 Apr 2010 at 9:19pm
the amp meter on my wf moves left to right rapidly when the tractor is running, what causes this ?  it is a 6 volt, with generator and positive ground, and has recent new wiring. I am not sure it really charges, starts some times, then not other times, has i think clean ground, and  new heavy heavy cables. Js
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2010 at 9:38pm
It sounds like your armature is out of round and the brushes are bouncing. It is probably charging some, if you don't want to get the gen. checked out try putting a voltmeter on the battery to see what the voltage is at startup then after you have run it a while. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 7:55am
Just had a customer recently that had the same kinda problem. Drove him crazy for a while. He had the Gennie checked out locally and his rebuilder couldn't find anything wrong with the unit. I told him to change the Ammeter out just for the heck of it from one of his other Tractors and see if the same problem exists. Turned out to be the problem. New Ammeter, and he was back in business. Goofy things happen sometimes....   lol!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 3:13pm
thanks steve i hadn't thought of that, will try it first then go to a rebuilder if that doesn't work.
