Welding spindle support
PTOman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PTOman Quote  Post ReplyReply Direct Link To This Post Topic: Welding spindle support
    Posted: 16 Aug 2024 at 1:34pm
52 CA spindle support weld which have been previously rewelded broke and I need to get some ideas on what size and type of welding Arc rod to use and amperage anybody has had some experience with this thank you
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 1:49pm
I just welded my 1962 gas D-17 spindle support about a week or two ago.
The crack was discovered when I greased the support.  Grease was leaking from the bottom side of the top of the support.
I degreased the area the best I could.  Ground a deep chamfer into the crack.
My first pass caused the grease to heat and run out.
I then used a rose bud to heat the crack until the grease no longer was running out.
Reground the area to be welded.
Welded with 7018 (1/8") at 95 amps.
After each weld, the weld was ground down.  This was done to insure there were no slag inclusions.
I just checked the weld with dye penetrant and no crack was present.
This tractor has a 500 loader and is used primarily to move large round bales.
I suspect the spindle are was cracked when the lights went out and the tractor contacted a 9" diameter post.  Good thing the tractor was at idle speed.
Edited by Clay - 16 Aug 2024 at 6:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 5:16pm
i use 7018 rod 3/32 diameter on almost everything.. Set about 90 amps.. You have to VEE out the crack to the bottom and weld out so there is no left over "crack" to start a second failure.. I grind all the metal to clean, no rust, no paint within 1/2 inch of the weld.. No preheat is needed if the parts are less than 1/2 inch thick, but if the metal is below 30 degrees, i preheat the area to get up above 100 degrees.
This page was generated in 0.075 seconds.
