Welding Rod ID???
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: Welding Rod ID???
    Posted: 10 May 2010 at 1:53pm
I have found some thin rod's in my stash, and they are E308-16 and HarrisWelco 315, they are very small dia, I have been welding rust holes/cracks in rusted mower decks with good success. I have an old Lincoln AC, running at 40 amps. When I grind the bead it appears bright like SS or Nickel?? Any thoughts? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 2:14pm
The 308-16 appears to be a chromium, nickel rod used for welding stainless.
http://msds.ihs.com/partinfo.aspx?partid=23378
Google has the answers.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 3:16pm
The 308 is a stainless steel rod used to weld 308 (and sometimes 304) stainless. The 315 rod is also a stainless rod that can be used to weld 315 and/or 321 grades of stainless. Neither rod was marketed for welding stainless to steel.
dbaileyky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbaileyky Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 5:01pm
308 is a stainless to stainless weld 309 would be a stainless to carbon steel weld
This page was generated in 3.908 seconds.
