WDBottom end is gettin freshend up too! |
Post Reply |
57WD45FarmUse
Silver Level Joined: 01 May 2019 Location: NE Kansas Points: 88 |
Posted: 10 May 2019 at 6:28pm |
Wellhowdy. I got my head back today from the machine shop and what a beautiful sight to see! I can’t picture myself slapping that thing back on my ole block that has one dished piston... so I decided I’m goin to at least get a flat top to match the other3 as well as new rings and wrist pins and of course it get all miked up.
Bearings Seem fine to my eye and touch. As well as the Lobes on the bumpstick. Lookin for input and suggestions from anyyall out there in AC Orangeland with familiarity in WD engine buildin specs. Hints and tips from the ones who have been there and done that! This Tractor does alot of hard work for me and my lil farm. Thanks to everyone out there for all the help! |
1950 WD, Adjustable WF, 12v, PS, New style OK Tractor 3point hitch. Kelly front loader. Farm Use Only
57WD45FarmUse
Head came home today... So puurdy!
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8277 |
57,
New complete kit may be the way to go. More money than one piston but then you would have a matched set, and the rebuild would be good for many years. Head and manifold look fresh and ready to go. Regards, Chris
festus51
Orange Level Access Joined: 26 Mar 2017 Location: Osage City, KS Points: 1639 |
Sugarmaker that is my thoughts also. Specially while it is all ready apart
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
57WD45FarmUse
Thanks man !
Yea I figure that’s the best is to have all 4 new. So what do ya no about the 45 kit as they call it in a WD block. Been doin some reading. Looks like a crank and pistons and it’ll be fine with my short head. It be nice to have that extra power. Is it worth it I’m wonderin |
57WD45FarmUse
Yea. I’m thinkin so. What do ya no about the so called 45 kit? Do ya think it’s work me buyin a new crank or just be happy with a fresh bottom end ?
festus51
wd cylinder is 4x4 wd45 is 4x4.50 I think you would need a 45 block to put the 45 pistons in it. Plus the crank is different but I'm not sure what the is. I think wd will have a shorter stroke. Bear in mind I am not an expert on this. Maybe some one with more knowledge will chime in. My personal OPINION would be to just put a WD kit in it. No fuss no muss
57WD45FarmUse
Beins im already scrapping pennys togather fer this bottom end job it’s lookin like tryin to do the 45kit is just gonna be to costly. And like I’ve said before that WD had more than enough power to do what I need before any TLC. Can’t imagine the after results
Thanks |
Tim NH
Orange Level Access Joined: 16 Oct 2012 Location: Lancaster NH Points: 1084 |
I have four used WD flat top pistons. You can have the best one free. Tim
Sugarmaker
Tim's offer might keep your budget intact. I think I may have a couple 4 inch WD flat tops too. Not sure of condition?
WD45 crank should work in the WD block. But the farther you go the deeper the water!:) I am going to have way more in the tractor I am doing, than I will ever be able to get out of it. My goal is for one of the great grandsons to pull it about a dozen years from now!:)
Regards, Chris |
Orange Level Access Joined: 12 Sep 2009 Points: 20485 |
The 4 1/2" stroke crankshaft of a WD45 fits right into a WD block, but you need to use pistons for a WD45. The air cleaner is bigger as is the carburetor on a WD45. Looks like you already have a WD45 manifold.
BE SURE TO REPLACE THE CAMSHAFT BEARINGS !!!!
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
Another thing to think about is the sleeve O-Rings. You don’t know how old they are. Time is as hard on them as anything. It would be a shame to do all that work only to find coolant in your oil one day. If I was in your shoes and I could find the money. I would put a new engine kit in. Shop around. Last one we bought for the 8050 got a heck of a deal from minpar. All ago parts. Good luck
Edited by wekracer - 11 May 2019 at 6:51am |
Sugarmaker
57,
Great projects just take a while. I have had the same concerns on the tractors I have worked on. My WD could use a engine kit. Just not sure I want to get into it.
Good luck with your tractor. Some good suggestions and lots of information here to help you. Regards, Chris |
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1465 |
Best tip is to get everything machined and balanced properly, technology has come a long way since those engines were new. Full rebuild now and you'll never have to worry about it in your lifetime |
Sugarmaker
Bill,
Good looking WD rebuild! That is one thing I did not do, balancing the rotating parts, I didnt even think about it. Regards, Chris
57WD45FarmUse
Hey Thanks Tim. I’ll keep ya in mind!
57WD45FarmUse
Hi Dr
I think my Marvel Schedbler TSX773 is also a WD45 piece . Just got the refresh kit from Mikes l And oh yea I’ll get them camshaft bearings ! Thanks Edited by 57WD45FarmUse - 11 May 2019 at 9:37pm |
57WD45FarmUse
Hey yea I didn’t even think about sleeve orings. Hmm I see these engine kits go fer round 4-500 bucks I thinks that’s what I’ll do.
57WD45FarmUse
Holy mackerel. That thing is beautiful!
I will Forsure have it machined and balanced. Thinkin on just havin the machine shop install the pistons rings etc etc while they got the block anyhows. Then I’ll put the top back on and reassemble from there up |
57WD45FarmUse
Hi Chris.
Yea I’m just gonna havta deal with not havin her up and runnin again as fast as originally planned. But will be worth the extra Wait many times over!!! |
57WD45FarmUse
Just an update on the paint there Chris. I got my first coat on today. She looks so Happy |
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 288 |
I sill have a lot of WC, WD, WF engine parts for sale, cheap. See first page of classifieds on this site.
Sugarmaker
57,
Its going to look and run good too! Good work! Regards, Chris
Post Reply | |
