WD45D
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: WD45D
    Posted: 20 Nov 2016 at 12:13pm
Where are you getting the correct rubber hose at the injection pump on a WD45D?  Thanks...Dale
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 12:50pm
I use low pressure power steering return fittings and fuel hose, makes a nice looking hose and cost is lower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 12:53pm
Where do you get a head gasket without going thru Agco ?
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 1:05pm
I bought a valve cover gasket from OKtractor.com.  They carry the head gasket also.  The Allis number is 74514398.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 1:08pm
Tony Carbaugh has them also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 1:18pm
Doug, I have some new head gaskets I don't use that have the fire-rings made into the gasket and don't like to use them and I'd let go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 1:27pm
I have one of those hoses with my NOS Wd45D parts lot for sale.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:20pm
have a question for you plow gurus,on a 14 in mold plow,how many horse power per bottom does it take?i have heard several figures and realize that the depth and soil conditions are the key points.....thx
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:28pm
I always figured 12-ish, but your mileage may vary. This is at the drawbar. A WD45 will 4-14s in lighter soil on flat ground. In heavy clay on hilly ground 2-14s will be all it can do.
Edited by DougS - 22 Nov 2016 at 8:31pm
