WD45
Steve R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 07 Oct 2010 at 9:44pm
I have a problem on my WD 45 - It will not idle down, throttle all the way closed engine still runs 3/4 RPM. Happened all at once. Any idea of what the problem is? Any suggestions would be appreciated. Steve in Illinois
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 10:17pm
Sounds like a govenor weight came apart.
You'll have to pull the distibutor drive out to check.
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 6:10am
could be the carb to make sure the butterfly is working freely. had 1 that  a screw came out and other screw was loose did same thing.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 7:01am
              I think Dave is right on the governor.
                                 John Carlson
