WD45 with 433I runs rough smokes bad cold??? |
Page <12 |
pirlbeck ![]() Silver Level ![]() Joined: 01 Dec 2009 Location: West Central IA Points: 229 |
I have had other engines that I have had to deviate from the factory spec to get to run correctly. I am always a little hesitant to advance pump timing very much from the stock setting as I have seen piston failure as a result of too much static timing advance.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5112 |
This pump should have a "push-pull" advance trimmer screw, so that means you'd need to run it IN to get more advance movement earlier.
Ops......I thought you needed to turn them out for quicker advance. I will play with it again when I get the injectors back in it as I don't think it starts as well set at 23 degrees. Thanks for the help!
Edited by pirlbeck - 04 Apr 2018 at 12:42pm |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8656 |
does the 433 have the rubber ring in balancer? Ya know a lot were slipped on 301's throwing timing marks off.
From looking at it I am pretty sure it is solid......no rubber at all that I can see.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
guys as stated before - the spitting and slobbering when cold is the nature of the beast and made even worse w/o a muffler as in a 6080. Ruff idle is or probably is the elastocast rubber ring on the weight retaining bracket.
Almost every engine with 1000 hours or more does this that I have seen - the 6080's down to the 2200 in fork lifts. . Now this issue should go away after a minute or two after the throttle is cracked and boost is obtained a couple of times. If it still idles rough it is the rubber washer afore mentioned. |
Injection pump was recently rebuild so I don't think that is the problem. As far as being the "nature of the beast" the way this thing runs when the static timing is set to the factory spec of 18 degress is not normal. At part throttle it misses, slobbers and smokes bad and it runs like this regardless of how long it has been running.
Edited by pirlbeck - 05 Apr 2018 at 7:24am |
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Post a video
Wink I am a Russian Bot |
just because the pump was "recently rebuit",I wouldn't rule it out especially if you don't know the reputation of the rebuilder.
The only thing that will cause that is erratic timing assuming the engine is ok (valves, setting, injectors and air filters). Also I would never touch the advance trimmer w/o a timing needle inserted.
The other thing to check is the turbo - check the intake manifold and intercooler for oil contamination. Droplets of oil will not burn well at low rpm. As the boost increases so does the temp and the back pressure on the turbine shaft on the compressor sided. Also, an injector nozzle dribble will also complicate matters. As stated previously, always verify TDC on the crank pulley and the timing mark on the fuel pump . Trust but verify.
Edited by tbran - 06 Apr 2018 at 3:41pm |
Page <12 |
