WD45 Width |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: WD45 WidthPosted: 17 Jun 2011 at 4:30pm |
What was the min./max width of the tractor at the rear wheels?
Charlie
Jeff(WD45-SATX-TN)
Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Posted: 17 Jun 2011 at 4:43pm |
Mine had 12.4x28 tires. All the way in I measured 74", that is actaully at the wheel center as it is the widest point with the tires spun all the way in. When all the way out I measured 89". Not 100% sure on the widest. That was where mine where when I started trying to turn the wheels in. They appeared to be at the end of their travel, or the widest point. Hope that helps. Jeff |
1954 WD45 NF "Iron Tater"
Charlie175
Posted: 17 Jun 2011 at 7:14pm |
thank you. Making sure it would fit on a 77" wide trailer
Charlie
Dakota Dave
Posted: 17 Jun 2011 at 8:30pm |
Rear tread width is 56 to 90 inches. thats center to cented. for out side you need to add the width of a tire. if you have 14.9 thats 72 inches at inside stops. fist stop on each wheel will be 76". I went out and mesured mine it matches that.
bluebanshee
Posted: 17 Jun 2011 at 10:24pm |
I think thats what our deck between wheels trailer is. WD we got recently was partly spun out so we had to take the fenders off to get it on the trailer. I know the 45 with them spun in fits with at least 6 inches. Fully spun out I was thinking its just over 8 feet wide. But I could be wrong on that.
