WD45 wheel weights |
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Topic: WD45 wheel weightsPosted: 28 Feb 2011 at 9:01pm |
I got a set of wheel weights for my WD45 the other day front and rear. Been setting in the neighbors barn for years and sunk down in the dirt. He just gave them to me. I got them all painted up, should be putting them on tomorrow. How much to the fronts weigh an how much do the backs weigh? Also what is the average price of a complete set? Thanks.
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 28 Feb 2011 at 9:04pm |
I have paid 100 for a set of rear ones, and up to 200 for a set of front ones. the rears weigh 135 lbs each, and the fronts I think are 90 lbs each
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18962 |
Posted: 28 Feb 2011 at 9:13pm |
Here we go again, everything is out East... DARN!! You got a REAL GOOD Deal on those, enjoy!!
Edited by Ted J - 28 Feb 2011 at 9:14pm |
79fordblake
Posted: 28 Feb 2011 at 9:25pm |
Can I bolt the front wheels weights to the inside of the wheel? Looks like the center is big enough to go over the hub to me. They are kinda an eyesore on the outside by pics I have seen. I bought longer bolts than I really need I think.
For the back I bought bolts long enough that I can add another set of weights later on if I want. |
79fordblake
Posted: 01 Mar 2011 at 6:03pm |
Got the weights on today. Front weights fit good on the inside of the wheel but was rubbing the axle(found out the bushings were wore out). I didn't know the bushings were in such bad shape until I jacked it up. So I put the weights on the outside instead.
How hard is it and do I need special tools to replace the bushings? Also is there a way to take slack out of the steering in the gear box? My tie rod ends are in good shape. ![]() |
