WD45 Valve Lash
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Valve Lash
    Posted: 23 Nov 2023 at 6:30pm
Could someone tell me what the valve lash should be on a WD45
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 7:06pm
I'm thinking it was 15 cold and leave alone. Doc may pop in with the #. Runs in my mind that it's 2 more than hot spec.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 7:22pm
Operators manual calls for .012 hot. So .014 or .015 cold should do it. Easier to set cold and at least they will all be set at same temp. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2023 at 7:37pm
The service manual calls for .013 valve lash. Does not specify hot or cold. Strange that it is not the same. I set mine a few years ago but don't remember which number I used.
This page was generated in 0.049 seconds.
