WD-45 turbo kit
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2010 at 9:42am
Originally posted by Gary in da UP Gary in da UP wrote:
 Well , if one good, two should be more better. Twin turbo's and an intercooler, maybe a whiff of NOS, and on it go's
anything that puts more air into the cylinder makes that engine come to life .with its wide lsa it can handle large doses and it has plenty of exhaust scavaging in stock trim
Edited by mlpankey - 09 Oct 2010 at 9:44am
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 10:51am
Now please bear with me.  I have been working on turbo engines for a long time.  None are what you would call high performance engines, they are all high efficient industrial engines and big.  Some have turbos that weight 2000 lbs or more.
I have also read up about turboing small gas engines and found two different camps, one is for large turbos but they spool up late in the game but give high outputs.  This is what most cars do, even the little 2.2L dodge turbos.
For a working tractor however or a pickup/work vehicle there are very few gas turbo vehicles out there.  The guys that I have read about said that if you do turbo one you want to pick a turbo that goes on an a performance engine about 60percent of the displacement of the engine that you want.  So, say for example, a 226 *.6 would be 135 which is about 2.1 liters.  So if you took a 2.2 liter dodge turbo/wastegate and put it on a wd45, you would have a much better "working tractor" system.  It wouldn't be a powerhouse necessarily for pulling but would have better efficiency and some more power without lag, especially midrange and at high idle.  There surely has to be a way to put a downdraft carb after the turbo instead of before like this guy does.
Also, I have studied and sized oil bath air cleaners before.  They are set up for a certain CFM based on 1 cylinders intake and don't work well at idle (don't get enough oil pulled up) or at higher cfms(pull oil into the intake instead up condensing/precipitating back to the cup)  I would think the kit/turbo would suck oil out and there fore dirt with it without going to the next size up aircleaner.
Seems like the size of the above mention kit would only power at high idle and even then wouldn't come alive unless you really opened the governor up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 12:08pm
I would want to blow through a larger updraft carb. and use a k and n filter on the inlet side with the pipe going through a box filled with 10lbs of dry ice. whats your thoughts on the 2.0 volkswagon diesel turbo.
Edited by mlpankey - 10 Oct 2010 at 12:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 1:31pm
The smaller tubo's I was mentioning would be for farm use, not pulling, at least not dry ice type pulling.
I imagine that the 2.0 vw turbo would work well for that but if you want to pull and are opening up the governor you would want a bigger turbo to pull with.  Something off of equal displacement or at least 80 percent displacement.
Problems with blowing through many carbs is that you cause float/needle seat problems.  You have to pressurize the bowl as well to equalize the pressures or you have problems.  Make sure you have good throttle shaft seal as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 4:38pm
If I were going to farm I would own a newer than 1950 era tractor. i thought on updraft carbs the air velocity entering syphon the fuel up from the bowl through the jet .
Edited by mlpankey - 10 Oct 2010 at 4:38pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 5:16pm
Updrafts  do siphon fuel,in  your earlier post  stated you wanted to blow thru, and there lies the problem.  Like fire brick states the updraft needle and seat won't be happy with that arrangement.   A downdraft would be more better, but I see more plumbing and some fancy governor linkage to make it work, and probably a fuel pump, as gravity might not be reliable. You can do it Mitch.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 7:14pm
VW diesel turbos would not be my first choice for gas tractors, as they are not made for the exhaust temps that gas engines can see.  Also, VW TDI turbos have a vacuum controlled vane actuator (and the older waste gate ones I believe are vacuum controlled also).  Additionally, most TDI engines have a turbo that is integrated with the exhaust manifold.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 7:36pm
hurst i was just thinking about a low rpm diesel turbo making boost at gas tractor rpms. I do however think 1200 f is 1200f  on any internal combustion exhaust.  garry i was thinking that the piston created a depression wich is measured in vacuum making the  air inlet pressure entering the updraft 14.7psia on a naturally aspirated .so at seven pounds of boost a seven pound fuel pump should keep things equal . most down draft carbs that are made into blow thru carbs have the boosters and venturi  worked over to create  the correct signal .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 7:56pm
smuggler what would you do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 9:06pm
The way the VW turbos work is they have a computer controlled solenoid valve that opens and closes the vanes on the variable geometry turbo to control boost.  It may be possible to find a pressure controlled actuator that will fit and work properly.  I feel like the earlier turbos would be a better fit, as they are wastegated turbos and cost considerably less.  Maybe something like a Garrett GT15 or a KKK K03 would be good.  These were used on early gas and diesel turbo VWs and are some of the smallest turbos around.
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 6:25am
I would tend to think to make the turbo any turbo effecient fuel and ignition timming would need to be mapped to each psi of boost wich would require onboard computer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 6:40am
Another thought on the carb issue when blowing through is box it up. Remember the old Paxton superchargers? On carbureted installations they had a box that the carb was in.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:12am
I've got a question for AlinIL why would it only give a allis 20 to 25% increase when it gives the M-450 an 80% increase @ 10psi and the 460-806 100% plus increase and olivers a 100% increase.
B212,716,two 314H's,WC,WD,D19,190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 9:28am
There is a line some where on what psi you can boost and not box it up.  I want to say its 7psi?  Any thing higher and you need to.  Under that if you plug the bowl vent and pressurize it,  it will work if your carb is in ok shape.
If you are worried about timing maps, why not go to a gm throttle body, a crank sensor  and tie every thing together with a megasquirt Mplanky?  You can adjust the timing galore as well as the injection.
What RPMS are you shooting for?  That is going to be the biggest deciding factor in turbo size.  Do you care if the power is mostly on top?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:20am
making hp now thats bending rods at the rpms we are capable of turning . I was just brain storming on the turbo .  400 ci 226 d17 block n/a 3400 rpms with tires hooked when they blowup traction 5000 is blimped till the chip catches up.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 3:42pm
Good - My estimate is based on 7psi (Super M) and what I have observed at antique tractor pulls.  They just dont seem to have much add power(dont seem to spool up fast enough).  I assume in field conditions that the extra power is there, since load conditions occur at a slower rate. - AL
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 4:02pm
the antique pulls i've went to are stock rpms. when the tractor pulls down on rpm the turbo will slow. It looks cool but in my style of pulling it wouldn't  hold its power. My thaughts are displacement is better.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 5:37pm
I emailed these guys, the price is 1550$ plus shipping.
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 7:32pm
allis fields if it was 100 plus ponies it wouldnt pull down did you get the pics of the bottom end?
Edited by mlpankey - 11 Oct 2010 at 7:33pm
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 12:16pm
I see what your saying Al,most pulls around hear though let you be 10 to 20% over on rpms but there not going to let a turbo 45 pull in the stock class anyway just hope for a 4000# open class.I am thinkin twice about getting the kit. I have a fresh engine in a wc that has 45 crank with overbore pistons but I used WD pistons to get compression up and it's pretty close to 9to1. I am wondering if thats to much comp. for a gas turbo setup because they talk quite a bit about having low comp.but then again the diesel is 16to1. What do you guys think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 1:48pm
It's the difference in fuels. More compression = more heat. More heat = more chance of dentonation (pinging). Diesels don't ping because the fuel isn't there on the compression stroke until the pump pushes it in. Dentonation, pinging, spark knock is basically the same thing. The fuel is being set off by something other than the spark plug. When the fuel ignites from 2 different sources like a glowing bit of carbon and the spark plug, and when the 2 flame fronts collide, the huge spike in cylinder pressure makes the knocking sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 3:29pm
good fuel 110 or better ,timing backed off a little she would be fine at 9to1  . run it on methanol and you can have a turbo with 12.1 pistons. ps i would run a msd ignition with boost  timing control or a three step that  retard timing as boost rose .
Edited by mlpankey - 12 Oct 2010 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 4:27pm
Pretty much race fuel huh? I suspect the days of going to the air port to get AV fuel are gone. What I used to do with my old Torino that was about 11:1 was put Sunoco 93.5 in it and about 6 moth balls. It seemed to like that "home brew".
