WD45 transmission
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: WD45 transmission
    Posted: 24 Jul 2010 at 10:23pm
My WD45 shifter popped out of place & the transmission was stuck in reverse. Pulled the snap ring out of the top of the shift tower and removed the shift lever. I tried a long screw driver to shift it into neutral but but I couldn't budge it. So I pulled the top off the transmission and drained and flushed it out, everything looks good. Put the transmission and the shift forks in neutral. The problem I have now is getting the long fork into it's coller when putting the top on back on the transmission. The two on top are no problem but the long one is not cooperating. What am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 7:15am
Try shifting the tranny AND the shift cover into second gear positions....it's a challenge to get one of those back on correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 9:37am
It seems to me I tipped it to the left. Then while dropping it back in you rotate it to the right. Sounds easy enough.
This page was generated in 0.035 seconds.
