WD45 throttle issue |
MACK
Topic: WD45 throttle issuePosted: 05 Feb 2011 at 9:37pm |
Shorten the linkage between the gov. arm and carb. by bending it down if every thing is free. MACK
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 05 Feb 2011 at 6:40pm |
i am with BRIAN start from scratch with the governor adjustments differnce in governor wear can cause your problem
Brian Jasper co. Ia
Posted: 05 Feb 2011 at 12:08pm |
What about governor adjustment? With the throttle lever opened wide, the link from the governor should be able to travel about 1/8" past wide open on the carb when disconnected. If the governor isn't adjusted right, it might be your problem.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6119 |
Posted: 05 Feb 2011 at 12:02am |
Hmmm... how's ignition timing? What's the chances your advance weights are binding, and once it picks up enough, they swing out, and won't swing back?
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 04 Feb 2011 at 4:12pm |
Make sure that the linkage that comes out of the governor goes across the front of the engine and pulls on the carb moves freely my WD started sticking their a couple years ago and acted like that.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
jdsellers
Posted: 04 Feb 2011 at 4:01pm |
It was another old governor that was tried. Who's to say that it was any good, it just acted the same way with either one so I sort of ruled it out at the time.
Thanks for the insight guys.
I will check it out and let you know what I found.
Edited by jdsellers - 04 Feb 2011 at 4:03pm |
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 04 Feb 2011 at 1:24pm |
sure sounds like the linkages are sticking, unhook the rod from the governor arm and the carb and see if everything moves freely, also check bushing on the governor shaft that goes through the front cover
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 04 Feb 2011 at 1:14pm |
Is something binding on the throttle rod, maybe the carb butterfly valve is sticking? But I would suspect the new govenor also?
Still in use:
R.W
Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Posted: 04 Feb 2011 at 1:07pm |
Did the spare govener work right?
jdsellers
Posted: 04 Feb 2011 at 11:57am |
I've got a WD45 that was rebuilt a while back. It had WC pistons put in the 45 block, which bumped up the compression ratio. The engine runs great, but the throttle response lags then overshoots. What I mean is that when you throttle up it's delayed for a split second. Once it revs it doesn't ever want to stop and will essentially try to overrev. Now when you start to throttle down you can balance it out somewhat, but the throttle balance is delicate because it's in a different spot when the engine is loaded and unloaded (just cruising around). The only troubleshooting done was to replace the governor with a spare, but no change in function. I haven't checked the timing yet, it may be too advanced? I don't remember anything else that was done to it. Does anyone have any suggestions on what to look for? Thanks JD |
