wd45 throttle adjust |
joebanana
Topic: wd45 throttle adjustPosted: 20 Nov 2014 at 2:58pm |
Hello
New to the forum and orange family. I have a wd and a wd45. just recently purchased the 45 and have had the wd for most of summer. I also have jensales operators and service manual. Now the question. My wd idles fine, and as I move the throttle RPMs gradually pick up until reaching full throttle or if set for half throttle, that is half way on quadrant etc. On my 45 starts and idles fine, but by an eighth to quarter throttle I am at wide open throttle. any thoughts would be much appreciated? Thanks in advance Joe PS once that emoticon is on there I gave up on trying to remove it. although still glad to be here. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8627 |
Posted: 20 Nov 2014 at 3:28pm |
Joe,
Welcome to the Allis forum! Nice tractors! Some pictures? Couple things come to mind that I found on the first WD we got. It would start and then the throttle lever would work downward and the engine would start to increase RPM on its own. the issues were: 1. The compression spring under the quadrant was worn out and soft. 2. Each joint in the throttle rod control system was worn about 1/8 inch. I think there are 3 locations. 3. The optional spring on the carb rod was no where to be found. This goes down and hooks on the drain for the block. Helps control idle on early WD's. 4. The big spring under the tank was not the right one, and was not helping return or hold idle. After going through these RPM linkage items and fixing them, the tractor preformed about like a new one. I was worried that the governor was bad. Since then, this is one of the first repairs I look to make. Hope this helps. Regards, Chris Edited by Sugarmaker - 20 Nov 2014 at 3:37pm |
joebanana
Posted: 20 Nov 2014 at 3:36pm |
Thank you. the wd45 would not have the spring to block then? Correct? that appears to be the only spring missing. also obvious i think? the carb on this on is a marvel vs zenith. did read a post on this site after trying a search other owner found fork on governor worn. still will check linkage wear? just seems like carb opens way to early and easy.
Sugarmaker
Posted: 20 Nov 2014 at 3:43pm |
Joe,
All those joints and the govenor are designed to keep that carb steady and not acting weird. That doesn't mean something could not be wrong this the carb. Have you tried holding the rod to the carb and moving it slowly to see what happens? And yes the spring was eliminated on the WD45. Regards, Chris |
Posted: 20 Nov 2014 at 4:33pm |
Start with the basic adjustments. Engine off. Throttle wide open. Disconnect the governor link rod behind the generator. Now check the length of the link rod. It should slide back into the vertical governor arm hole without moving the vertical arm while pushing the link rod rearward.. Bend the link rod in the middle to shorten it to correct length. Start engine and try it out.
Sugarmaker
Posted: 20 Nov 2014 at 5:55pm |
Great to have experts on this site. Maybe this is why the Allis I am working on had a bent rod behind the generator? Sorry if I question everything, but is the bending of this rod in the Allis manuals somewhere? Sorry I don't have a repair manual yet. But it is on the list.
Regards, Chris |
Posted: 20 Nov 2014 at 6:00pm |
A-C had a tool to bend/adjust the vertical governor arm. It is very rare to ever have to make the linkage longer.....always shorter. Much easier to pull downward on the link rod to shorten it, unless you have the official governor arm bending tool. And I prefer to make the rod 1/16" to 1/8" shorter than full open, but that's just me.
joebanana
Posted: 21 Nov 2014 at 8:22am |
Thanks Doc
will give it a try. the link rod is from cross shaft to carb, correct? also prior to doing so I Know i have read somewhere (oper. or service manual) that the rod from the bell crank to control shaft adjusted by wide open and then pushing rod shaft all the way in and tighten set screw? at bell crank? do first? fI would guess. may be way off base |
joebanana
Posted: 21 Nov 2014 at 8:46am |
By7 the way, wd at farm, and 45 in garage, very cold in WI right now, will try to get pics up soon. Is there a welcome area in the forum, if not Might I suggest incorporating one?
no offense, just have case garden tractors (Orange as well) and has similar topic in forum, great place for newbees. also does any still follow storage procedure in maunual. obviously battery and fuel are a concern. usually change oil prior to winter, combustion particulates in oil from normal operation, vs fresh oil. nI just make sure freeze protect good on antifreeze. I guess only thing left, tires off ground? wd45 as liquid in them |
Sugarmaker
Posted: 21 Nov 2014 at 8:48am |
Joe,
Welcome to the Allis Forum. You will fit right in with the WD and 45! Regards, Chris |
joebanana
Posted: 21 Nov 2014 at 8:54am |
Thanks so much again,
I am sure off that. always seem to find good ole people who still consider their word as binding. Nothing better than farm folk I have found. sure wish the world didnt become driven by greed, as I have always said in the customer service business, People like to be served and not sold. Met more true friends that way. So Far nothing but pleasant experiences here. |
joebanana
Posted: 21 Nov 2014 at 1:00pm |
The DOC is in the House.
![]() Thanks so much runnin like a champ!! nice smooth acceleration right up to WOT!!! Joe |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8745 |
Posted: 21 Nov 2014 at 9:42pm |
I think you will be the only tractor owner with tires off the ground for winter if you go through with it.
Sugarmaker
Posted: 22 Nov 2014 at 7:39am |
Glad the Dr fix worked for your 45. He had a great basic suggestion. I will file that one away too!
How about a picture of this tractor? Regards, Chris |
joebanana
Posted: 23 Nov 2014 at 11:16am |
Ok sugermaker, see what I can do. let me tell you about the Saturday I had from allis standpoint, checked out an ad that said farm stuff earlier in week and guy set up appt for yesterday. said he had a cultivator off an AC. when i bought the wd in june, prior to the wd45, the guy gave me a (tool bar) said you mount cultivators to it. So I show up to see this cultivator yesterday, he didnt have any idea how it went on, nor do I. I will get some pics of everything and post under new thread as the subject should be cultivator assembly help i would guess LOL
![]() Joe PS Suger, checked the linkage's and will also definitely need some as there as well. ![]() |
Sugarmaker
Posted: 23 Nov 2014 at 8:31pm |
Joe,
Sounds like you came home with more equipment. Congratulations! I may not be of much help on the cultivators. Dad had cultivators for the WD but I never seen them on the tractor. He let them set out behind the barn and they were not in good shape when the farm was sold. Regards, Chris |
hopper
Posted: 10 Jan 2017 at 8:51am |
I am having problems with my governor as well. i have an early wd and it doesn't have a spring on the throttle but i think it did as i found part of a spring that looked like it might have gone there. the wd doesn't like to start very easy i have to put my hand over the carb for the air intake and pull the tarter for it to start. Can anyone tell me whats wrong with it? also what does the tool look like for the bending the governor rod as i have found some wierd tools in the tool box when i got it.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 10 Jan 2017 at 9:19am |
Welcome Hopper!! As far as the hard starting goes I would make sure the choke lever is fully closing the choke when you pull it. I believe there is an adjustment for this at the carb so that it will function just the same as you putting your hand over the air inlet.
1957 WD45 dad's first AC
Leon n/c AR.
Joined: 19 Mar 2013 Location: Heber Springs A Points: 176 |
Posted: 10 Jan 2017 at 9:58am |
Hopper on the M-A carb choke butterfly there is usually a small spring loaded butterfly with a spring to let air in once it starts and probably spring or even small baffle are missing. Leon
Sugarmaker
Posted: 10 Jan 2017 at 10:36am |
Hopper,
Welcome! You might want to start a new thread on your tractor issues. Lots of things to check before you start bending things. Also carb type and some pictures may help too. The first WD I brought home had engine revving issues till I went thru and brought all the mechanisms back to spec. Like springs and worn joints and adjustments. Regards, Chris |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1529 |
Posted: 10 Jan 2017 at 12:24pm |
I have a 1954 wd45 - all original. Mine has the spring at the back of carb to block drain. Thx, Ed.
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 11 Jan 2017 at 8:26am |
I use two box end wrenches. One to support the rod and the other to bend it. Not the best tool but if you are careful it works. If the weights are loose this will also cause poor governor response. Not a bad idea to check the weights. It's not common, but I have seen a few weights wear out and fall into the timing gears.
Where in Wisconsin are you located?
hopper
Posted: 12 Jan 2017 at 5:40am |
i made a new topic for this and will try to get pictures on it.
