WD45 Steering Shaft Universal - Removal
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Steering Shaft Universal - Removal
    Posted: 28 Aug 2010 at 9:45pm
Need some expert advice. I have a new throttle quadrant for my WD45 to replace the broken one on now. Here is the situation - The steering wheel is pretty much rusted to the shaft. I dont think even loose juice with heat will get it apart. SO, I want to remove the shaft from the univeral, then replace that too. For some reason the pin just will not budge more than a 1/8" or so. Any experience from the field on this? Has anyone had success removing this piece?
Thanks Jeff
1954 WD45 NF "Iron Tater"
Dennis IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:22pm
Jeff, I remember replacing the steering shaft universal on my WD years ago but I don't recall having any trouble. You can always try a little heat. If you do put heat on it I would definately replace the universal though because any high heat transfered to those little roller bearings in the universal caps is bad news!     Dennis.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:27pm
If you carefully center punch the pin and take your time it (they) can be drilled out.  Replaced mine with roll pins and put a tie wire through them just in case they decide to move. Heat will destroy the rubber seals and boil the grease out of the bearings.  Good Luck!
Edited by Osage_Orange - 28 Aug 2010 at 10:28pm
Why is there never time to do it right the first time, but always time to go back and fix it?
rob(ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob(ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:27pm
Pin is tapered. Will only come out one way. Good luck. Rob.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:30pm
My pins would not budge (either way).  Maybe you'll get lucky and be able to drive them out.
Edited by Osage_Orange - 29 Aug 2010 at 7:34pm
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 7:29am
I replaced my quadrant not long ago. I removed the steering wheel pretty easy.
I used some heat and a suitable puller and it came right off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 9:59am
Thanks for all of the advice everyone. I have an angle drill, sounds like drilling them out will be the way to go. I like the roll pin and tie wire idea as well. No worries on the heat, the universal is shot anyway.
Jeff
