WD45 SC Lift Latch Repair
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 SC Lift Latch Repair
    Posted: 01 Jun 2010 at 5:26pm
I am rehabbing a couple of latches that I bought through the Forum. Can someone tell me if the pin in the latch body (part that slides onto the SC arm) to which the latch springs attach is a single pin that goes all the way through? Both ends are broken off, and it appears to be thoroughly rusted into the tube it goes through.
Thinking that it is a solid pin, I am trying to remove it using heat and a drive pin. But no joy thus far.
Other suggestions? Anyone have luck drilling them out?
Thanks a lot for any ideas!!
WC, CA, D14, WD45
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 9:07pm
If I understand what your talking about, I believe those are the small twist rivits that press in.  mine were broke off, and I drilled most of the way, then was able to get an easy out on the rest and twist it right out
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 9:19pm
Larry, I have those twist rivets and could drill out enough of the old material to insert them. Thanks.
WC, CA, D14, WD45
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 3:58am
Yes, It is .
"Burgie"
