wd45 pulling hitch
bubschooley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bubschooley Quote  Post ReplyReply Direct Link To This Post Topic: wd45 pulling hitch
    Posted: 05 Mar 2011 at 11:45am
Looking for some ideas on a adjusting pulling hitch for a wd45 tractor. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 11:51am
How much are you trying to adjust it?   What I did was remove the snap coupler bell and then I made a hitch  that picked up the shaft that the bell pivoted on.   On the back, I just used some longer bolts and some spacers to get the drawbar up or down, and used the other pivot brackets for the drawbar support to adjust the other way.  I could have made a whole new drawbar support, but with our height and distance from rear axle center to hitch, it wasn't worth it.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:38pm
 Use a pin hitch front half drawbar. I had Phil  Brown from Farley  Ia.  Build Mine He's within 50 miles from you . He can build A very good one . He goes bt d17brown on here.
Allis orange blooded by family. Allis Diehard by choice
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 11:07pm
   I just took a D series straight draw bar and cut it off short as legal. Put it in the standard yoke, and use washers to fine tune the height. It works great.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 7:51am
X2, like Harold Omaha, ours looks just like his. Works great.
