WD45 PTO drain vs torque tube drain
FireMedic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FireMedic Quote  Post ReplyReply Direct Link To This Post Topic: WD45 PTO drain vs torque tube drain
    Posted: 17 Oct 2024 at 9:47am
Checking all the fluids in my tractor. The drain to the PTO released light brown compromised oil. The drain directly forward of that PTO drain (at the torque tube) looks like perfect oil. Is there a seal between these two compartments? If so, where are the most likely points that I’m getting contamination of the fluid in my PTO? I would’ve expected both of these to be transmission based and share fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 10:01am
